Might if made a mistake..rebuilding my head
preludeachris
295
3
Sep 29, 2011
Lincoln, Nebraska
So when I bought my new lifters, I let them soak in oil and installed them, the other day I was reading about someone having a clicking noise and he said something about not "bleeding the lifters" before installing them? I just soaked mine and popped them in so to speak did I miss a step??
Not bleeding them, you run the chance of bending valves upon startup. Reason being that the lifters are essentially pumped up and pretty stiff. If you installed them though and didn't start the car immediately, eventually they will bleed off under tension. Have you ran the car since?
Mine were noisy for a while after i replaced them too, sound went away after a few mins tho.
