2G MFI Relay and Fuel Pump relay not getting signal
JoshMc
93
16
Nov 18, 2015
Kansas City, Missouri
Its a 1996 gsx, with the factory ecu, but I just finished getting my car back together finally, and went to go start the car, and everything is functioning fine except the fuel pump not coming on, I checked both the mfi and Fuel Pump relay out of the car, and they both switch over as they should, so I know the relays themselves work, however for some reason when they are in the car, they aren't getting the signal to switch over... So my question is, what can cause this issue? I'm sure being electrical the possibilities are endless, but Looking for any advice, or if someone else has had this issue before, any help would be greatly appreciated!
so I think that could possibly be my issue as well, anyway you could tell me which connector is supposed to be plugged into the brake fluid one and vise versa? I had the entire harness removed from the engine bay and when I reinstalled it I suppose I could have switched them, have any pictures on which exact connector goes where? Thanks
@JoshMc - On a 1995 the relay received power from a thicker white / black stripe wire. Test that pin to make sure that's receiving power. It's from IGN 1 which some people hack into for remote starters.
Also check the wire at the MFI relay that comes from the fuse box (it's a thicker red one - can't remember the color of the stripe).
