fuel pump relay
maxtsitalon
33
Jan 4, 2006
Wausau, Wisconsin
i need help finding the fuel pump relay on a 92 fwd tsi. the haynes manual does not show where it is. I'm not gettin power to my new pump i just put it in. any pics of the location or just general help would be generally appreciated. thanks.
there is no "fuel pump relay" per se. Power comes from the MPI Relay, which will be attached to the RH side of the center dash behind the radio. Pull the radio out, and you'll see a gold box with a plug on it, its measures about 2'' square and it'll be right in front of the ECU. If that isn't the problem, and you are sure you wired it properly, check your ECU. Pop it open, see if the caps are leaking. If so, its probably the ECU. When those caps leak the first thing they leak on is the MPI control/Fuel control circuitry. Thats bout all I can tell you man.
