Methanol octane rating
-DSM2NR-
602
12
Dec 9, 2005
Tucson, Arizona
Quick question. I'm getting a methanol kit. How much octane points will the methanol raise the fuel? How much will a 50/50 water/methanol mix raise 91octane.
I'm pretty sure it does raise octane. That's why you don't really need to buy racegas when you have a methanol kit...
As a general rule a 5% mixture of methanol will raise octane by about 1 - 1.5 points. So a 50/50 mix should equal about 100 - 105 octane (figuring 91 octane premium). The true octane could be much higher though...Reason below.
It's pretty hard to narrow down an actual octane rating for methanol or ethanol since the way they calculate octane is based on gasoline. Alcohol fuels have intake temperatures that gasoline fuels will never see. While octane measurements of alcohol fuels put octane between 100 - 110, the actual octane is much higher due to the higher cooling properties.
If you don't believe me, remember this: Running straight methanol (I know you're talking about meth injection) will cool your intake charge so much that you can run without an intercooler. Lets see any C16 race gas do that.
  • For sale 91-96 Auto DSM 300M Upgraded T-Case (USED)
    one of spares , brace is not included. Buyer covers shipping / fee.
    • The_Partout_Spot
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
