MegaSquirt DIY Kit?
a review states that everything is there and "easy" to assemble because everything is labeled..
this is what i'm looking for xD can i buy this locally? usa,va for about the same price??
:rocks:
do i still need a safc even though i would have a pecu??
is there a quick switch profile feature?? or do i have to dis-connect & re-program it each time??
get the stim to make sure everything works, I built mine without it and got lucky.
I'm trying to figure out what Kit to buy. If this is all I need in this kit id rather spend $250 rather than $600. Here is the kit MegaSquirt-II Programmable EFI System PCB3.0 - Kit w/ BLACK CASE DIYAutoTune.com I dont mind spending the time to put it together I just want to know what else I would need to get.
At the very least, you will need an additional ignitor to make the ECU compatible with the 420A and a harness to install the ECU. A stimulator isn't a bad idea either, especially if you have never built a Megasquirt ECU before.
