damaged trace- MEGASQUIRT
reborn750
106
Oct 7, 2010
Brookings, South Dakota
I jumped into this megasquirt ecu with not near enough knowledge and understanding. At this point i feel like i have quite a bit of experience and know how. I recently sent in my MS2 ecu that i purchased for my eclipse as a last resort to the no start. It took about a month but i have my results back. They found a damaged trace supplying power to the injector driver circuit. They told me they believe the damage was due to high system voltages and that i should ensure my charging system is working correctly before installing my ecu. I am very curious to what is the actual cause of my problem and want to fix it before my ecu arrives. It cannot be the alternator because although i am using the symtech supplied voltage regulator, my alternator belt is not on, nor have i tapped the regulator into the power yet. I have a 5A fuse on the power wire going to the injector harness powering all 4 injectors, although the attached megamanual diagram shows the power wiring being split in two with 2 5A fuses. Would this create a problem. For a little history, the car WAS running but poorly earlier this year when the ECU was just installed and standalone harness, 1200cc injectors installed. All at the same time i ordered a new harness, milder 650cc injectors, and had the ecu sent back for IAC and a 2-step rev limiter installed. I rewired the entire car doing it right and very carefully. From this point out the car NEVER ran again. It ran when manually fed fuel through the TB but never on its own. Timing is spot on, and fuel system was just plumbed correctly and all new. This makes me wonder if it was something done while symtech was in posession of the ecu. I dont want to accuse anyone and i definately dont want to assume its a problem on their end when its something with my wiring and have the same thing happen again. Any ideas or suggestions to what it could be? Help is greatly appreciated. Car is a 97 eclipse 420a using ms2, and tunerstudio. also the wiring diagram below is not the one used for my car, just shows an example of how they split the red power wire into two, using two fuses to the injector harness.
It's hard to say without knowing specifically what trace you're talking about, but if it's the one I'm thinking of, that's a very rare failure. It could've happened due to high system voltages, or perhaps it was just a fluke. Typically the MOSFET driver would have to draw a lot of current to burn that trace. You didn't mention what kind of fuse you have connected to pin 28, but a 2A fuse should have prevented something like this from happening.
5A is pretty high -- enough to allow damage to occur if there's a problem. I would swap it for a 2A fuse. The ECU doesn't really need more than 1A to operate.
I will replace the fuse with a 2 amp right away, thanks for the input!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
