megasquirt water temp
kongo
168
Jan 8, 2009
new orleans, Louisiana
My water temp sensor will drop 50 deg after a couple of minutes. Ill drive a few miles then it will drop from 186 to 132. The car will still run the same,but on tuners studio theirs a 50 deg drop. Would that be signs of a bad sensor or something else. The car doesnt run different. Just that its reading different. Its stock air and water temp sensor on the mega squirt 2 ver3 running 2.1.0q firmware.
I'm surprised its not running different. Did this just happen all the sudden? Could be a bad sensor but could also be a bad ground or something.
I'm believing bad sensor. But be sure you have the proper amount of coolant and checking with an "turkey baster" thermometer would verify.
MB
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
