Master Clutch
_DDSM_
Feb 23, 2012
Westchester, New York
i have a 1995 gsx and i want to know what that valve is between the Master clutch and the slave cylinder because i'm losing pressure at my foot when i step on the clutch and i just put in a slave cylinder
It goes
Pedal assembly -> master cylinder -> metal tubing along firewall -> flex line (below fuse box) going to slave cylinder
The master cylinder is located deep in the drivers side firewall with a small fluid reservoir on top of it, next to brake fluid reservoir
Did you bleed the new slave cylinder? That may be the problem
Look up in the footwell and look for fluid leaking from the push rod going into master cylinder
Example picture attached
    • Sdcryan1
