Mass interchangable?
stomp
117
Jul 17, 2007
Vernonia, Oregon
I finally got a dreaded code po100 Mass circuit malfunction ,and I found a used Mass for 40 $ on Egay but it only says it fits 95-98 Turbos is there any differences to a 95 turbo Mass to a 99 gsx Mass?
No, but verify it actually is a DSM MAS..you never know what you get off FleaBay.
It's off a 97 Galant ,..would that work?
There is not a cold air intake pipe made for either the Spyder GS or the 7G Galant. However, both cars utilize the same Mass Airflow Sensor (MAS) as the 2G Eclipse turbo.
http://4g64.150m.com/faq.html says they're the same apparently. 7G Galant = 94-98
Also is that code po100 just directed at the mass(circuit malfunction) or could it be else ware?
Wiring to and/or the ECU itself could be the culprit as well (short, leaked capacitor blowing grounds/tracks, etc).
