manifold bolts into turbo
Order the OEM conical washers. When used properly, they apply spring tension to the bolt to keep it from coming loose.
You'll need a total of 8 washers, 2 per bolt. EXTREME PSI : Your #1 Source for In Stock Performance Parts
I would try to find them elsewhere for cheaper unless you are getting more parts due to the $7.50 handling fee.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
