tsi1991awd
- 1,366
- 6
- Sep 28, 2008
Puyallup,
Washington
I have been having a problem with boost. I have been boosting 20+psi even WITH the MBC turned all the way out (basically stock setting at this point)
I tested the wastegate actuator at 10psi coming from the air compressor, arm barely moved. Tested it with 25psi and it still barely moved. Tested it with 40psi and still barely moved....the video below is at 40psi. I tested it with 80psi afterwards and still moved the same.
Isn't the arm supposed to extend more??? I will post a video someone else took, just for comparison sake. First two are my video, last is someone else's.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/LTHyZ3VOqhM&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/LTHyZ3VOqhM&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/nb473NHb5UQ&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/nb473NHb5UQ&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/1Bicn4-C8bg&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/1Bicn4-C8bg&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
