Is this normal or is there a problem?
Spaniel1287
195
Jan 30, 2005
Daven, Iowa
When im drivin my 95 Talon TSI FWD Automatic everything runs great except for this minor (might be major but i dunno) problem that i see. When I get on my car alot and floor it i can look out my rear view mirror and see a good amount of exhaust gas looking smoke come out as im hittin teh pedal to the medal. Is this a problem or is it normal becuase my rpms are liek at 5 and 6000 so it just does it. ALso it is liek 40º-50º where I live right now? Any help please?
Not enough information here. What kind of modifications (if any) do you have? Do you have a logger to log with? We need more info.
No my car is totally stock. I just want to know if thats normal for like a gust of smoke to come out ur exhaust when u floor it. I am gettin an Apexi N1 Downpipe and full 3" stainless steel exhaust here in the next few weeks u think that will help it or what?
White smoke usually means that antifreeze is getting into the exhaust which usually means your head gasket is gone.
Unburnt oil can sometimes seem whitish, this is what I would do:
1. Inspect the turbo for shaftplay, check licp and ic for oil.
2. Do a compression test, dry and wet. This will give you some indications whether rings or HG are in play.
If 1 and 2 yield nothing, I would say valve seals may be in question. Good luck.
  • Wanted 6 bolt NT water pipe
    • chrisman287
