Main Ground Wires
94nonturboGS
83
Aug 13, 2006
Lincoln, Nebraska
What are the main wires that I need to run to properly ground everything in the engine bay? So far I have the starter to the Tranny and thats it, so obviously i need to run one from the tranny to the chassis, but what else other than that? Thanks.
The Battery neg to the starter mounting bolt on the tranny.
The Battery neg to the firewall.
Intake mani to the firewall
Tranny to the pass side frame rail.
I threw a couple other grounds around the engine bay for good measure.
-One from the IM to dr side strut tower
-One from the battery neg to the pass strut tower area where there was an unused threaded hole.
-One from the alternator adjusting bracket to the radiator support area where there was an unused threaded hole.
It doesn't sound like you have the battery neg post connected to anything???
I had the neg side hooked up to a ground somehwere but i just cant picture it right now, but i will put those other grounds in there.
