1G Main Bearing Clearances?
craracer05
Supporting Member
357
90
Sep 29, 2005
Warren, Ohio
So went and did some measureing on my block tonight to try and figure out if I can get this car back on the road.
i measued all the main caps at 61mm all the cranks mains at 56.74mm and my clevite 77 bearings at 2.28mm thick.
from what I figured that makes me .0059" of an inch too tight?????? :hmm:
The stock reccomended clearances are .0008 through .002
Try to use some plastigage and see how that reads.
I have heard of people using as large of a gap as .006 in racing applications. But I have No first hand experience with that.
My engine was .002 on all Mains and rods.
The proper way to measure them is by putting the bearings in the block/cap and torque the caps to spec. Then measure with a telescoping bore gauge or something similar and subtract the crank journal diameter.
I plastigauged mine and that was sufficient for me. They were between .002 & .0025.
And .0059 would be way too loose. .003 is about the max I would feel comfortable running and then you would need to run heavier weight oil to ensure you had good pressure.
Did you measure these with the main caps, bearings installed and torqued? If not your numbers as mentioned are off. This is because the torqueing process stretches bolts/studs firmly beds main caps into thier respective block registers, and apples a known amount of crush to the bearings.
If a dial bore is not available for measuring the bearing clearances with the bearings and main caps installed and torqued, without the crankshaft, then I would also reccomend the plasti-gauge method.
Ya i"m just going to get a plasti gauge and see whats up, I returned my dial bore gauge last year when I ditched the project. But does anyone know the listed size for the block main bearing bores?
Well through it together today plasti-gauged it and cam up with .04 to .05mm on all the mains. Which accordding to my service manual is right on spec towards the loose end.
That comes out to .00157-.00197." The service manual calls for .0008-.002" with a service limit of .004". So as you said, you are on the loose side of the OEM spec.
3 of mine were .002, with one at .0017 & .0025. I have no balance shafts and run 10w40 Castrol to make sure I have sufficient oil pressure. I have 6,000 miles on the build.
I think you will be fine, as long as you measured them correctly.
I dare anyone to mod their car while running the .0008" listed in the manual. That is a joke. On a car with any real power i usually go at least .0025". I also delete the balance shafts. These cars have a great oiling system, at least the 6-bolts. This allows the use of a proper high performance oil clearance. You should see what the nhra guys run.
