- Ownership Status
- Currently Own
- Year
- 1994
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Drag Race
- Mods-Bolt-on
- FP Zero with ported and coated 10cm turbine housing
FP race manifold with porting and thermal coating
JMF O2 housing
Tial MVR wastegate
ETS FMIC 4" core w/ 2.5" piping
FP Intake & Filter
Apexi N1 turbo-back exhaust
knock off Tial BOV
Fuel Lab AFPR (STM)
FIC 1650cc injectors
Magnus V3 cast intake manifold
S90 74mm throttle body
Walbro 535lph pump rewired with 8awg
- Mods-Engine
- 1g rod/2g piston combo with ARP rod bolts
ARP head and main studs
Mild port work on head
Cometic MLS head gasket
Crower springs and TI retainers
Crower 272s
3g lifters
- Mods-EMS & Logging
- ECMlink V3 with Speed Density & Flex Fuel
- Mods-Drivetrain
- Fidanza Aluminum Flywheel
ACT 2600 w/ street disc
Shifter cable bearings & symbroski shifter kit
DSS 3" Aluminum driveshaft
S.S. clutch line
- Mods-Handling
- Megan Racing Coilovers
ST front & rear swaybars
Poly rear subframe mounts
EVO9 wheels
S.S. brake lines
Hawk pads
- Parts Wishlist
- Real Tial BOV
Built Trans or Auto swap
Built block
- Background
- Bought the car back in 2007 from a SBR employee before they moved to Florida. Chassis was formerly owned by Curt Brown and was one of his 16g cars. I finally put it together in 2013 after moving to a house with my own garage.
- Dyno HP
- 350 whp
- Dyno TQ
- 300 lb/ft
- Dyno Video Link
- Watch Video
- Dyno Shop Name
- TPG
- Dyno Session Details
- 18psi run only, wastegate not holding.
