main bearing clearance
zulimee
Dec 11, 2010
connecticut, Connecticut
tuner,
i have 1 question.. how to check oil clearance with plastic gauge.. 1-5 main bearing..
Are the main bearing oil clearance between 1 and 5. If among the five oil clearance is not the same. What should be done, whether the need to reduce main bearing cap bolt torque ...
i see manual spec... and i torque all bolt to spec torque.. i see the plastic gauge at main bearing 1,3,4 same oil clearance and 2,5 not same with 1,3,4.. what should i do.
How are you laying your plastic gauge and you should have no oil residue on the one you are checking, it should be clean on both halves.
Of course no oil in back of bearing.
DO each one separate.
