Main and Rod Bearing oil clearance.
white7g
May 7, 2015
Charleston, South Carolina
Im building a 2.4l with a 2g head and just getting ready to build the engine just got all my parts back from the machine shop. Im using manley h beam roads and manley pistons and was wondering what the rod and main bearing clearances should be. Not sure if still use factory clearances or not since this is going to be around 450-500hp once finished. thank you!
