maft question
tsi2fly1991
40
Dec 21, 2003
scottsbluff.ne, Nebraska
I have a few questions about the maft does it help with fuel cut and what do you have to upgrade to install I was just wondering because im hiting fuel cut around 5500 rpms at 10 to 12 pounds of boost and i tried every thing to fix the problem and nothing seem to work so im thinking it might be a mafs problem if i retard my timing all the way and it dont cut out it just pings bad.
thanks jeremy
Two things:
First of all, in order to avoid fuel cut, you need to understand what causes it. It's caused when the ECU sees to much airflow, so you need to either remove the fuel cut feature from the ECU, or you need to make it see less airflow. You can make it see less airflow by installing larger injectors, and then using a piggyback (VPC, SAFC, GCC, AFR, MAFT) to reduce the airflow signal.
If you install a MAFT by itself and keep the stock injectors, then you will probably make it worse.
Second, and more importantly: you should not be getting fuel cut at 10 psi, end of story. I don't know what your setup is, but I can't think of one that would really make that likely. I'll bet my full 3" exhaust that you have a bigass boost leak somewhere, inflating your airflow signal.
You're simply not flowing 27+ lb/min of air at 10 psi.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
