maf-t wiring
rdmartin1162
Nov 15, 2006
chesterfield, Virginia
Hey, I have a 2g maf translator. I need to hoop it uo in the car but my plug has been cut. Anyone know how to wire it in without the plug? What color wire from the translator goes to what color on wiring harness? Any help would be greatly appreciated.
This might help some
The wiring from the maft to the ecu:
Pink - +12volts
Green - MAF frequency signal
Black - Ground
Brown - Air temp signal
Gray - Barometric pressure signal
White - RPM signal
The wiring from the maft to the GM MAF:
Pink - +12volts
Yellow - MAF frequency signal
Black - Ground
MAFT wire - MAF plug pin 2G
Pink - Pin 4
Green - Pin 3
Black - Pin 5
Brown - Pin 6
Gray - Pin 2
White - RPM signal
there a picture of the plug here
http://www.dsmtuners.com/forums/showthread.php?p=151120125
