Maf T question
In draw through (pre-turbo) sure. In blow-through, not so much. It would be far more trouble than it's worth to adapt the stock rubber UICP to couple to a 3-3.5" MAF. You can pick up a used aftermarket UICP, cut and bead the pipe end or you can pick up a UICP made for GM MAF blow-through set-up.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
