ECUflash MAF AirCounts & SD AirCounts
It is taking me a really long time to dial in the gm maf without SD and MAF AirCounts. I really am getting annoyed with it, and i am letting the car sit until I can figure out why i do not have it in my EVOscan. Since it is nearly impossible to get a good set up without the 2 AirCounts.
I'm having a hard time figuring out why you are trying to use those 2 log items to dial in a gm MAF sensor......OMGWTF
Going from stock 2g MAF to 3 bar GM MAP sensor. Sorry if it may have not been clear. GM MAP... not MAF. MAF AirCounts is talking about the stock MAF while SD AirCounts is talking about MAP sensor (or speed density). I still have not found the issue
Just adjust the SD table based off your Target AFR Vs the Actual Afr. Even if you got everything logging perfect it's never going to truly make the map for you... .
The amount of time spent trying to figure out the logging you could have had it tuned. :)
What Xml are you using in Evoscan? What version et cetera?
Using version 2.7. I just figured it would make tuning sooooo much easier with the maf aircounts and sd aircounts. im really suprised no one else has encountered the same issue.
