MAF vs SD -- weighing my options
90_Talon_TSi_AWD
5+ Year Contributor
61
4
Jul 12, 2019
Kokomo, Indiana
I've been comparing costs for MAF and harnesses just to get a feel for what that route would cost me versus taking the ECMLink plunge.
For those with previous Moates experience, should I be able to assume that a SD-wired setup is ALREADY wired for an ECMLink SD-setup?
Or would I need to factor in harness costs for the ECMLink plunge?
I have no experience with Moates, but I can tell you that the ECMLink SD cable puts the MAP sensor on the BARO pin so that you could conceivably run with a MAF as well. I don't know exactly what pin Moates expects (and I guess that's what you're asking here) but worst-case it should just be a matter of swapping two pins if it's not correct.
No experience with it here either but even still, I wouldn't "assume" anything. Where are the sensors wired?
