2G Lowering spring question
Casem13
81
9
Apr 15, 2017
Olympia, Washington
I’ve seen posts like this a bunch and they all have the same answers. Here is the issue. I’m trying to get lowering springs for my 97 gsx. I already have Koni yellows, but I’ve been trying to find lowering springs. I wanted to get the eibach prokit. But it’s no longer made, same with H&R springs, tein, and many others. They only offer them for front wheel drive. And I know the gsx uses different ones for the extra weight. I see a lot of sites posting saying they fit all eclipses when I know that is bs. So can anyone link me to a set of good lowering springs. Thanks
I have been planning to lower my 2001 Spyder GT. From what I have read they say you should also change struts and shock also. Then there are kits to correct cast and camber... I`m a bit confused with the hole thing ..I`m just want to close the gap between my tire and fender so my wheels don`t look so small .
https://www.autoanything.com/suspension-systems/20A53672A1.aspx
My bet is that most manufacturers found that the difference in spring rate for standard lowering springs wasn't worth the production effort to make two different models when the cars could use either, so they just went to one spring rate for the rears of 2g cars. All websites I see offer one spring type for 2g rears.
If it's that important to you, then you may have to go with coilovers, order custom springs or find someone that has true gsx coils for sale.
I just want a good pair of lowering springs that work for the gsx due to the extra weight
Check the weight specs of the springs you want, manufacturers may have gone to a middle ground rating to mediate costs. I'd be willing to bet you'd be fine with any of the offerings available, especially compared to stock.
The weight difference in the rear is about 180lbs of sprung weight IIRC.
Yeah I’ll have to check around. A long time ago I made the mistake of buying ones for a non-turbo and it was supposed to do a 1 inch drop but it sent me car straight to the ground so I sent them back. I found one of the vendors on here sells lowering springs that it lists for gst/ gsx so I’ll probably just have to go with that
You will need a camber kit as well, if you want your camber to be in spec when u get it aligned.
I know if I don’t go past like 1.3 inch drop I shouldn’t need a camber kit due to it not being lowered much. I’m not trying to go super low because that’s tacky and ridiculous. Just trying to close the gap some in the wheel wells
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
