420A Low wiper fluid light on
mechsbox
May 17, 2022
Spokane, Washington
I noticed the low wiper fluid sensor was unplugged. It is because the sensor is broken. Its full of fluid and its on 24/7. The previoys owner put tape over the light on the dash. Anyone know how easy it is to fix?
Likely needs a new one, parts store might have one similer or find a used one from dsmgraveyard
If the sensor is unplugged and the dash light is still on I think you have more than a sensor issue.
Lets start with you creating a profile for this car, I saw an earlier post where you said this is your sons car a 96 Talon ESI but we shouldn't have to search for that information to help you. That's what vehicle profiles are for.
Based on the 95 Talon Manual I have, the NA gauge cluster for the washer light gets power from Junction Box fuse #8 and the other end of the light runs to the level sensor where it's switched to ground when the level is low. Disconnecting connector A-73 may effect other things because the connector has two other additional positions that I don't find offhand,
Since the light works by something grounding the Yellow/Green wire from the cluster and the switch can only do so if it's plugged in there might be a short or something else we've missed.
Sorry. I thought I made a profile for it. About the low fluid light: the light is only on when the sensor is plugged in but just never goes off and the tank is full.
The float inside might be stuck in the down position. When the fluid level is above the sensor, the circuit is open. Below the sensor and it completes the circuit triggering the light to turn on. I would remove the tank to test continuity in normal position and flipped.
Just read this and found mines stuck saved me $100 for a new one😎
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
