Wiper fluid not working
dsm1103
31
Jan 4, 2012
medina, Ohio
When I try and use my windshield wiper fluid the wipers will move but no fluid comes out. There is fluid in the tank. I have no idea where to start, whether its looking for something broke or clogged. Nothing is leaking. Anyone have any ideas? Thanks
Check that the lines didn't come undone, should be obvious but sometimes you expect it to be more than it is.
Check the hoses to make sure nothing came apart, hold the switch for the wiper fluid on for 10 seconds or so and look for leaking under your car, or better yet have a buddy help. If nothings leaking then either the hoses or nozzles are clogged.
Yes I hear the motor when I try it
Open up the hood and pull the rubber hoses off the bottom of the wiper fluid nozzles and try again. If you get fluid out of the hoses, the nozzles are clogged. If no fluid comes out, trace the hoses back to the reservoir while inspecting for cracks or leaks in the rubber hose. If none are found, disconnect the hose from the pump at the reservoir and try again. If nothing comes out from the pump, it is most likely the problem. Good luck.
