looking to get alittle help with my td05h big 16g
Kirkamus
104
Jul 11, 2012
27263, North Carolina
on my 97 gsx with full frontmount intercooler looking to find out where exactly i am to connect the other end of my boost controller after ive connected it to the wastegate actuator
it is indeed a big 16g and i have a turbotonics boost controller looking for little insight here thank you very much
there is no nipple on the side of the housing like some of them
Well you have to get a fitting welded into your jpipe or switch for an ebay compressor housing with one built in.... Or be like me and upgrade to the amount of boost it wants to push out ROFL
I had my local welder weld a 1/8NPT weldable bung into the J-pipe and then screwed in a 90* 1/8NPT to barbed nipple. There is also a thread on how to tap the compressor housing too if you wanted to go that route.
Tap 16G Compressor Housing
Wlemceo to Tnreus
P.S.
...Weld
P.S.S.
I forgot most people have aluminum J-pipes while mine is steel so if yours is aluminum, you'll have to buy an aluminum bung and a welder that can weld thin aluminum
First off is the boost controller a ball and spring controller or a bleeder style boost controller. Second you can use a port on the throttle body and it will work just fine.
I drilled and tapped the compressor housing when i had my e316g. I beleieve it was a hole for a coolant line bracket. I then put a 1/8 npt hose barb fitting in it with teflon tape. Obviously do this with the compressor cover off so you dont get shavings in the turbo.
