cracked big 16g
mootink
33
3
Aug 25, 2011
cda, Idaho
i have a i think its a big 16g and it has cracks in the exhaust housing. can i still use the turbo? where can i get wastegate actuator and would a t25 one work?
1.) Thats not a 16g, its a 14b or 13g judging by the compressor wheel
2.) No you can not use a t25 wastegate, and look at the classifieds for a used one
3.) I would suggest replacing that hotside but ehhh I'd rock it if i had no other choice.
That's normal bro for the cracking! As long as it doesn't go thru to the outside you will be fine. It seals up when your running the car and it heats up. I agree that's a 14b comp wheel! It's not really to bad I've seen worse! I have worse! You should port and Polish that sucker and throw it back on! Get it to look like this bro. :) Here's a pic of the 14b vs big 16g wheel!
when i google The serial number on the compressor housing i got this.
49178-01(40)0: 14B
49178-01(41)0: Big 16G
49178-01(42)0: Big 16G
49178-01(45)0: Evo I Big 16G
49178-01(46)0: Evo II Big 16G
49178-01(47)0: EVO III 16G
49178-01(52)0: Small 16G
that why i thought it was a 16g
49178-01(40)0: 14B
Not sure where you found those, but I'm pretty sure these are the correct serial #'s for the 14b:
14B
49178-01010
49178-01030
49178-01400
49178-01410
