looking for alittle help car wont Fire
Kirkamus
104
Jul 11, 2012
27263, North Carolina
my eclipse gsx 97 is turning over but will not fire and im wondering what possibilities of it could have been. when it died i was driving and changed from first gear to second gear and as i was starting to take off it just died didnt kill engine just when i pressed the gas pedal in it would not give any gas or nothing just rev'd all the way down and cut off. i never herd any pop or anything to that knowledge
almost to the point of getting her running wonderful again and selling >.<
Have you tested the 3 items; spark, fuel and compression?
Check for spark at all 4 plugs, verify that fuel is getting to the fuel rail and that your injectors pulse and check your compression.
We can go from there then.
when i use a screwdriver in my plug wires with it plugged to the coil pack it isnt creating any spark as far as i know all my fuses are ok but getting a tester tomorrow so ill check that tomorrow it is getting fuel to the fuel rail
have not tested the injectors as of yet gonna get a volt meter to make sure they produce fuel through them as well
well replace the coil packs and the fuses wires ohm'd out fine if i remove fuel from the fuel rail it does return which means the pump hasta be working as well compression is alittle low its at 130psi on all 4
how do u make injectors pulse?
like ive said before im not getting spark from the coils to the plugs ide love to use a obd link to check my engine code but i dont own 1 >.<
told a few other problems could be
crank shaft position sensor
cam shaft position sensor
so update
new wires
new plugs
new power TR
new coils
new crankshaft position sensor
new camshaft position sensor
new fuses on EVERY FUSE in the car LOL
still no spark to the coils >.< everything is wired correctly and triple checked by 2 other people as well
looking for more imput as well
fuel pump is good
fuel rail good
injectors are all ohm'd out and test fine
2g No Start Diagnosis
Seems to me like you're "shotgun troubleshooting" and just replacing parts and throwing money at a problem that you haven't LOGICALLY troubleshot. You might as well wrote up a list of everything that could cause a no spark problem and then throw a dart at the list with your eye's closed, then replace whatever the dart hit.
:dsm:
well the thing is those codes on power Tr and crankshaft and camshaft all were on it
the plugs and wires were put on like 2 weeks ago roughly from scheduled maint and the coils well those were my only real waist but yeah day at a time with it barrowed a obd this cleared all codes and figured why the hell not after i got no spark from coils that it had to be the coil packs at that point but ehh FAIL time to check timing and everything seems like a hella waiste now a days >.<
update
gone through the steps on how to diagnose a no start under no spark
EVERYTHING seems to be in new or working order under that ohm'd out and everything >.< bout to just say screw it and tow it to the dealership to have them handle this mess ### hell im so lost at what else to do
Take and unplug the coil pack at the three wire plug. That that plug you should have one wire that is 12v with key on engine off. If that's there then pull your fuel pump fuse or pull injector wires off of injectors. Now you'll need some on else to crank the car over. With a test light (alagator end on the + side of the battery probe the other two remaining wires are going to be a ground flash so your test like should be on off like crazy. Also make sure your testing the plug thats on the engine wiring loom side. Please do these things and let us know so we can help you out from there.
going to try this soon as i get someone over here to help me out
and have not checked ecu as of yet will check it today after school
update no signs of leakage but when i turn the key to the on position it kills power to most everything but with the key off i have power to them
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
