Looking for the right size injectors to go with my set up
WIKDGSX619
99
May 10, 2011
san diego, California
Wanted to get some opinions on injectors.im running a fully built motor on a 35r turbo....eprom ecu and afc....
You need a little bit more info than just that to find out what injectors you should run. How much hp do you plan on making?
Also need to specify what fuel you plan on running, as well as if you will be upgrading the turbo or anything else in the not too distant future
Well, he said an AFC, so that will limit the size injectors that can be run a bit. You could either A) Get a chip burnt for your setup and injectors you want or B) Use DSMlink and go as big as you want.
Also need to know if you're wanting to run straight 93, E85/98 or race gas.. A little extra info will go a long way.
We need to know what fuel you are intending on using..That would help out a bit..Also what kind of hp you want to hit..
On an afc your very limited to options here..If you plan on getting dsmlink..The possibilities are endless..
