Long cranking time. Suspecting low fuel pressure!!
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
When i initially bought the car, i had a hard time to start it, i had to crank it 4 or 5 times. I took it to the mechanic, and we replaced the fuel filter. The problem stopped, and it was starting right away. I decided later on, to buy a walbro 190, i installed it, and the problem came back. Long time cranking. I read somewhere that the o-ring pops off, and it causses long cranking times. So i decided to take it out again, but this time, i added a fuel hose, attaching the pump and the fuel feed line, so i wouldn't be using the o-ring that previously made my car blow 3 pistons, because of low fuel pressure. The problem apparently came back, so i replaced the fuel filter again, and my fuel pressure solenoid is still in place. What i noticed is that, when i unscrew the fuel filter banjo, fuel comes out but, very slowly, so i suspect that the system is not keeping pressure, and that i have to crank several times in order to build it up again. I noticed that if im driving, and i turn off the car, and i crank again within 10 seconds, it will fire right away. I guess its because it has pressure still. So, i decided also to rewire the pump, hoping it would fix the problem, but it did not. What else can i try?
Just for kicks, you may want to check the two wires that go to the ECUs temp sensor in the t-stat housing. If they are broken, you will also have a hard time starting the car when cold. If that's not it, I'd attach a fuel pressure gauge to the system to see what is really going on...
Jack
Had the same problem on ours. Turned out to be an air leak in the lines allowing the fuel to bleed back to the tank and need to re-pressurize when trying to start it. Tightened everything up, and the problem was solved.
Mike
