Low base fuel pressure
dsm1gturbotalon
Jan 1, 2003
Racine, Wisconsin
Today I installed 660cc injectors and a br fpr on my 90 talon awd. I was making an attempt to get the 255 fp in but couldn't get the fuel fitting off and gave up until tommorrow. I installed the fuel pressure gauge on the fuel filter and started the car up. I had a leak and put some teflon tape on the fitting, tightened everything up and there seems to be no more leaks. The problem is that the gauge is reading about 22 psi at idle. I thought base pressure was about 37psi. Does this seem to be a problem with the install of the gauge or with the fuel pump itself? Does it need to be rewired? I am going to try and get the new pump in tommorrow, any help on getting that fitting loose?
fpr? does that mean fuel pressure regulator? If so it should be adjustable and you could just reset you base fuel pressure.
Is the gage on the FPR? If so, it will read a few psi lower than normal. Adjust accordingly. Normally the fuel pressure is checked on top of the fuel filter. Also there are two ways to check pressure, with the vacuum hose attached to the fpr (26-28 psi), and without it attached (36-38 psi).
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Message 702-741-6987.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $240 + shipping and PayPal fees* just replaced the upper bushing with...
  • For sale 4G63 Heads/ head parts
    Heads/ head partsNever ran ready to bolt up 1G head Ferrea dual valve springs/ retainers...
    • Dsm_canadian_mike
  • For sale 2g 2G Spare Tire Trim & Tool Pouch
    2G Spare Tire Trim & Tool Pouch $40 + shipping and PayPal fees* tool pouch has the tools...
  • For sale 2g 2G AWD Fuel Filler Neck
    2G AWD Fuel Filler Neck $65 + shipping and PayPal feesYou must be registered to see...
