Logger plugged in Anti lock light on
LaN-
956
7
May 7, 2004
New Baltimore, Michigan
the title basically explains it but heres the low down
got a logger not to long ago and when i plug it in and turn the car on anti lock light comes on.
one thing to note is the anti lock light has come on before with even before i got the logger but i know the logger is making it happen also both my logger and my firends made it happen.
any ideas
also i apologize for any of this not making sense i got a &*&* of coffee in me right now (alittle hyper)
thanks
LaN-
Some older logger cables just make the light turn on.
These next generation Data-logger interface cables have some very incredible features such as an exclusive OBD 1 plug that simplifies installation. Never Again will you have to see your ABS light come on, or have to install your cable every time you go into the car. The Factory OBDI plug is easy and secure to install, no cheap spade connectors, just plug and play. The cables automatically turn themselves on when the first bit of data is received from the laptop or Palm, eliminating the need for an on switch.
yes ..when your datalogger or pocket logger is plugged it disables the antilock, and that might be why your light is on.
steve said:
Anyone that isn't auto on will simply because they ground the diag terminal on the DLC at power up.
ABS is now in diagnostic mode which means your car's ABS is not functioning. Steve said it best; older cables ground the terminal.
