Log with LOTS of knock
nefarious
64
Jul 25, 2005
Huntsville, Alabama
So I just recently got my car running again and found that I have TONS of knock. Below is a log with a 2nd to 3rd gear sissy pull.
The reason I did not go to WOT is because I am still babying the car while trying to break in the new bearings that I just put in. Long story short, I was forced to remove the balance shafts when one of the front BS bearings decided it no longer wanted to stay in its place. I figured while I was in there, I would freshen up the bottom end.
The manual boost controller is turned WAY down...not really sure what it is set at because i haven't made a WOT pull yet. The knock sensor is new.
Could it be bad gas? The car has been sitting for a while. Fuel filter maybe?
Any suggestions would be greatly appreciated.
I forgot to mention...no boost leaks either. System holds strong up to around 17-18 psi.
Phantom knock...looks like I get to do some more searching.
On a side note, once it gets into boost, I do hear what I would think is pinging or something similar to it.
phantom knock is false knock. you know its false because if you really got 43 counts of knock you would be kissing your motor goodbye! also because your tps was never over like 40%. your motor isnt knocking but your knock sensor is picking up false knock. how new is your knock sensor???
After reading just a few topics, I found that the phantom knock can be caused by just about anything and can be really hard to get rid of. I guess I can try to desensitize my sensor a little and see where it goes from there.
My knock sensor is brand new...the car has been driven twice with it in there.
How does the timing look to you guys? I thought it seemed a little odd to me but then again, I am still a little new to logging.
Anything able to rattle. I was helping this guy find better fuel in my area and he said his manifold heat shield was rattling giving his false knock. Also have another friend who had a bad transmission that was tinging and giving him false knock. New tranny and it pulls like hell he says.
James :laser::talon:
Here is an update:
I changed my fuel filter, added a little bit of teflon tape to my knock sensor, and checked my motor mounts. Upon inspection of the mounts, I found that one of the metal spacers that is inside the motor mounts was missing. I replaced that thinking that may have been my issue all along.
I drove the car again and below is a quick log.
It just doesn't seem right because i only seem to get the knock when i get into boost. I logged a lot more than what i just posted and pretty much everywhere else is 0 counts of knock. Once I get into boost (as shown in the log above) I get extreme knock which really kills my timing.
Phantom knock is evident when in vaccum. If you are boosting, still could be phantom but there is no way of knowing the difference. More than likely though, it's real.
I'm not too familiar with the datalogger you are using but you are running a bit lean. When the airflow get's to be higher than 400hz, usually at the point of spool up, the computer goes into open loop. That being the point, in your case, knock goes through the roof and timing through the floor. Screams not enough fuel... or heck... could be rich knock. Too much fuel will give knock also. IMO, you should check your plugs. Follow the link for a basic guidline on reading. that give some sort of idea.
Spark plug reading
could be due to bad gas. dropping that much timing with that much knock is gonna make stuff super hot, super fast. wouldn't do it too much. check injector resistance and make sure fuel pressure is up to snuff.
You are running lean, did you log this while cruising?
Your RPMs never go above 4.5K. Log a WOT in 3rd gear then post your findings! I want to see throttle position 100% or close to it.
Does it knock when you free rev the engine?
I chased knock for over a month. up to 43 counts of knock cruizing down the road. Trying everthing, ended up being the lifters. I swapped to 3g lifter and problem solved.
o2's don't look too bad, mine are around .82. I have a wideband though and tune with that, the stock o2 is not accurate enough.
This may sound crazy, but put a can of Engine Restorer in it and relog. This stuff helps with the 1g lifters pretty well and may help with the knock. I would try the 6cyl bottle which is less than $10. I used to have a similar issue,but at the time didnt have a logger but i could felt like the timing kick back at part throttle and car would lose serious power. close to what your first log would feel
I would like to see a WOT log as well
Just to answer any questions about my entire log, I decided to post it up:
Code:
<table BORDER="1" CELLSPACING="1" CELLPADDING="2" WIDTH="1713">
  <tr height=18 style='height:13.2pt'>
    <td WIDTH="6%" HEIGHT="18" style='height:13.2pt'><font FACE="Arial" SIZE="3">
      <p ALIGN="LEFT">TechnoMotive Datalogger</font></td>
    <td WIDTH="10%" HEIGHT="8">
      <p></p>
    </td>
    <td WIDTH="11%" HEIGHT="8">
      <p></p>
    </td>
    <td WIDTH="8%" HEIGHT="8">
      <p></p>
    </td>
    <td WIDTH="6%" HEIGHT="8">
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
    <td WIDTH="12%" HEIGHT="8">
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
  </tr>
  <tr>
    <td WIDTH="6%" HEIGHT="0">
      <p></p>
    </td>
    <td WIDTH="10%" HEIGHT="0">
      <p></p>
    </td>
    <td WIDTH="11%" HEIGHT="0">
      <p></p>
    </td>
    <td WIDTH="8%" HEIGHT="0">
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
    <td WIDTH="12%" HEIGHT="0">
      <p></p>
    </td>
      <p></p>
    </td>
      <p></p>
    </td>
  </tr>
  <tr>
    <td WIDTH="6%" HEIGHT="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">Time (secs)</font></td>
    <td WIDTH="10%" HEIGHT="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">Throttle Position (%)</font></td>
    <td WIDTH="11%" HEIGHT="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">Engine Speed (RPM)</font></td>
    <td WIDTH="8%" HEIGHT="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">Air Flow Hz (Hz)</font></td>
      <p ALIGN="CENTER">Knock Sum</font></td>
      <p ALIGN="CENTER">Oxygen Sensor (V)</font></td>
      <p ALIGN="CENTER">Timing Advance (°)</font></td>
      <p ALIGN="CENTER">Air Temperature (°)</font></td>
    <td WIDTH="12%" HEIGHT="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">Coolant Temperature (°)</font></td>
      <p ALIGN="CENTER">ISC Steps</font></td>
      <p ALIGN="CENTER">Injector Pulse Width (ms)</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">0</font></td>
    <td WIDTH="10%" Height="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">19.22</font></td>
    <td WIDTH="11%" Height="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">2250</font></td>
    <td WIDTH="8%" Height="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">107.07</font></td>
    <td WIDTH="6%" Height="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">0.51</font></td>
      <p ALIGN="CENTER">35</font></td>
      <p ALIGN="CENTER">97</font></td>
    <td WIDTH="12%" Height="12"><font FACE="Arial" SIZE="2">
      <p ALIGN="CENTER">184</font></td>
      <p ALIGN="CENTER">54</font></td>
      <p ALIGN="CENTER">2.3</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">0.4</font></td>
      <p ALIGN="CENTER">23.14</font></td>
      <p ALIGN="CENTER">2281.25</font></td>
      <p ALIGN="CENTER">163.75</font></td>
      <p ALIGN="CENTER">0.12</font></td>
      <p ALIGN="CENTER">32</font></td>
      <p ALIGN="CENTER">98</font></td>
      <p ALIGN="CENTER">61</font></td>
      <p ALIGN="CENTER">3.84</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">0.77</font></td>
      <p ALIGN="CENTER">23.92</font></td>
      <p ALIGN="CENTER">2343.75</font></td>
      <p ALIGN="CENTER">233.03</font></td>
      <p ALIGN="CENTER">0.06</font></td>
      <p ALIGN="CENTER">31</font></td>
      <p ALIGN="CENTER">63</font></td>
      <p ALIGN="CENTER">4.61</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">1.09</font></td>
      <p ALIGN="CENTER">2468.75</font></td>
      <p ALIGN="CENTER">258.22</font></td>
      <p ALIGN="CENTER">0.1</font></td>
      <p ALIGN="CENTER">4.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">1.42</font></td>
      <p ALIGN="CENTER">24.31</font></td>
      <p ALIGN="CENTER">2531.25</font></td>
      <p ALIGN="CENTER">270.82</font></td>
      <p ALIGN="CENTER">0.39</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">1.74</font></td>
      <p ALIGN="CENTER">2593.75</font></td>
      <p ALIGN="CENTER">283.41</font></td>
      <p ALIGN="CENTER">0.66</font></td>
      <p ALIGN="CENTER">64</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">2.07</font></td>
      <p ALIGN="CENTER">2781.25</font></td>
      <p ALIGN="CENTER">289.71</font></td>
      <p ALIGN="CENTER">0.7</font></td>
      <p ALIGN="CENTER">33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">2.39</font></td>
      <p ALIGN="CENTER">2750</font></td>
      <p ALIGN="CENTER">302.31</font></td>
      <p ALIGN="CENTER">4.1</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">2.72</font></td>
      <p ALIGN="CENTER">2968.75</font></td>
      <p ALIGN="CENTER">308.6</font></td>
      <p ALIGN="CENTER">0.37</font></td>
      <p ALIGN="CENTER">34</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">3.05</font></td>
      <p ALIGN="CENTER">12.55</font></td>
      <p ALIGN="CENTER">3000</font></td>
      <p ALIGN="CENTER">314.9</font></td>
      <p ALIGN="CENTER">0.18</font></td>
      <p ALIGN="CENTER">38</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">3.41</font></td>
      <p ALIGN="CENTER">10.2</font></td>
      <p ALIGN="CENTER">125.96</font></td>
      <p ALIGN="CENTER">0.84</font></td>
      <p ALIGN="CENTER">39</font></td>
      <p ALIGN="CENTER">44</font></td>
      <p ALIGN="CENTER">1.28</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">3.79</font></td>
      <p ALIGN="CENTER">2843.75</font></td>
      <p ALIGN="CENTER">56.68</font></td>
      <p ALIGN="CENTER">27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">4.18</font></td>
      <p ALIGN="CENTER">2437.5</font></td>
      <p ALIGN="CENTER">0.74</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">4.57</font></td>
      <p ALIGN="CENTER">20</font></td>
      <p ALIGN="CENTER">2093.75</font></td>
      <p ALIGN="CENTER">42</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">4.96</font></td>
      <p ALIGN="CENTER">20.39</font></td>
      <p ALIGN="CENTER">1937.5</font></td>
      <p ALIGN="CENTER">0.08</font></td>
      <p ALIGN="CENTER">58</font></td>
      <p ALIGN="CENTER">3.58</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">5.35</font></td>
      <p ALIGN="CENTER">19.61</font></td>
      <p ALIGN="CENTER">188.94</font></td>
      <p ALIGN="CENTER">0.04</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">5.74</font></td>
      <p ALIGN="CENTER">1968.75</font></td>
      <p ALIGN="CENTER">182.64</font></td>
      <p ALIGN="CENTER">36</font></td>
      <p ALIGN="CENTER">49</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">6.12</font></td>
      <p ALIGN="CENTER">2000</font></td>
      <p ALIGN="CENTER">81.87</font></td>
      <p ALIGN="CENTER">0.68</font></td>
      <p ALIGN="CENTER">37</font></td>
      <p ALIGN="CENTER">1.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">6.5</font></td>
      <p ALIGN="CENTER">2031.25</font></td>
      <p ALIGN="CENTER">62.98</font></td>
      <p ALIGN="CENTER">0.78</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">6.88</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">7.25</font></td>
      <p ALIGN="CENTER">1781.25</font></td>
      <p ALIGN="CENTER">0.63</font></td>
      <p ALIGN="CENTER">29</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">7.63</font></td>
      <p ALIGN="CENTER">1625</font></td>
      <p ALIGN="CENTER">0.33</font></td>
      <p ALIGN="CENTER">25</font></td>
      <p ALIGN="CENTER">1.79</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">8</font></td>
      <p ALIGN="CENTER">1500</font></td>
      <p ALIGN="CENTER">0.16</font></td>
      <p ALIGN="CENTER">23</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">8.36</font></td>
      <p ALIGN="CENTER">1437.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">8.73</font></td>
      <p ALIGN="CENTER">22</font></td>
      <p ALIGN="CENTER">2.05</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">9.1</font></td>
      <p ALIGN="CENTER">0.14</font></td>
      <p ALIGN="CENTER">24</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">9.46</font></td>
      <p ALIGN="CENTER">0.25</font></td>
      <p ALIGN="CENTER">187</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">9.83</font></td>
      <p ALIGN="CENTER">13.73</font></td>
      <p ALIGN="CENTER">0.59</font></td>
      <p ALIGN="CENTER">21</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">10.59</font></td>
      <p ALIGN="CENTER">1406.25</font></td>
      <p ALIGN="CENTER">0.43</font></td>
      <p ALIGN="CENTER">2.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">10.57</font></td>
      <p ALIGN="CENTER">1375</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">10.94</font></td>
      <p ALIGN="CENTER">0.8</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">11.31</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">11.68</font></td>
      <p ALIGN="CENTER">1531.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">12.05</font></td>
      <p ALIGN="CENTER">17.65</font></td>
      <p ALIGN="CENTER">0.72</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">12.42</font></td>
      <p ALIGN="CENTER">1468.75</font></td>
      <p ALIGN="CENTER">0.27</font></td>
      <p ALIGN="CENTER">28</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">12.81</font></td>
      <p ALIGN="CENTER">1687.5</font></td>
      <p ALIGN="CENTER">170.05</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">13.2</font></td>
      <p ALIGN="CENTER">1656.25</font></td>
      <p ALIGN="CENTER">4.35</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">13.6</font></td>
      <p ALIGN="CENTER">21.18</font></td>
      <p ALIGN="CENTER">1750</font></td>
      <p ALIGN="CENTER">59</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">13.99</font></td>
      <p ALIGN="CENTER">1906.25</font></td>
      <p ALIGN="CENTER">201.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">14.38</font></td>
      <p ALIGN="CENTER">2062.5</font></td>
      <p ALIGN="CENTER">226.73</font></td>
      <p ALIGN="CENTER">5.12</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">14.73</font></td>
      <p ALIGN="CENTER">24.71</font></td>
      <p ALIGN="CENTER">2187.5</font></td>
      <p ALIGN="CENTER">251.92</font></td>
      <p ALIGN="CENTER">5.38</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">15.06</font></td>
      <p ALIGN="CENTER">25.1</font></td>
      <p ALIGN="CENTER">2312.5</font></td>
      <p ALIGN="CENTER">1</font></td>
      <p ALIGN="CENTER">0.61</font></td>
      <p ALIGN="CENTER">65</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">15.38</font></td>
      <p ALIGN="CENTER">25.49</font></td>
      <p ALIGN="CENTER">296.01</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">15.7</font></td>
      <p ALIGN="CENTER">25.88</font></td>
      <p ALIGN="CENTER">321.2</font></td>
      <p ALIGN="CENTER">30</font></td>
      <p ALIGN="CENTER">66</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">16.02</font></td>
      <p ALIGN="CENTER">26.27</font></td>
      <p ALIGN="CENTER">2718.75</font></td>
      <p ALIGN="CENTER">333.8</font></td>
      <p ALIGN="CENTER">0.49</font></td>
      <p ALIGN="CENTER">99</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">16.35</font></td>
      <p ALIGN="CENTER">2812.5</font></td>
      <p ALIGN="CENTER">346.39</font></td>
      <p ALIGN="CENTER">0.21</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">16.67</font></td>
      <p ALIGN="CENTER">26.67</font></td>
      <p ALIGN="CENTER">2875</font></td>
      <p ALIGN="CENTER">371.58</font></td>
      <p ALIGN="CENTER">67</font></td>
      <p ALIGN="CENTER">5.63</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">17</font></td>
      <p ALIGN="CENTER">27.45</font></td>
      <p ALIGN="CENTER">3187.5</font></td>
      <p ALIGN="CENTER">384.18</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">17.34</font></td>
      <p ALIGN="CENTER">28.63</font></td>
      <p ALIGN="CENTER">3218.75</font></td>
      <p ALIGN="CENTER">396.78</font></td>
      <p ALIGN="CENTER">68</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">17.68</font></td>
      <p ALIGN="CENTER">29.41</font></td>
      <p ALIGN="CENTER">3593.75</font></td>
      <p ALIGN="CENTER">447.16</font></td>
      <p ALIGN="CENTER">0.41</font></td>
      <p ALIGN="CENTER">70</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">18.02</font></td>
      <p ALIGN="CENTER">35.69</font></td>
      <p ALIGN="CENTER">3750</font></td>
      <p ALIGN="CENTER">516.44</font></td>
      <p ALIGN="CENTER">73</font></td>
      <p ALIGN="CENTER">6.14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">18.38</font></td>
      <p ALIGN="CENTER">38.82</font></td>
      <p ALIGN="CENTER">3781.25</font></td>
      <p ALIGN="CENTER">667.59</font></td>
      <p ALIGN="CENTER">2</font></td>
      <p ALIGN="CENTER">0.53</font></td>
      <p ALIGN="CENTER">80</font></td>
      <p ALIGN="CENTER">9.47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">18.74</font></td>
      <p ALIGN="CENTER">850.24</font></td>
      <p ALIGN="CENTER">41</font></td>
      <p ALIGN="CENTER">75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">19.08</font></td>
      <p ALIGN="CENTER">3937.5</font></td>
      <p ALIGN="CENTER">40</font></td>
      <p ALIGN="CENTER">55</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">19.41</font></td>
      <p ALIGN="CENTER">3375</font></td>
      <p ALIGN="CENTER">50.38</font></td>
      <p ALIGN="CENTER">0.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">19.73</font></td>
      <p ALIGN="CENTER">3125</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">20.06</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">20.44</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">20.83</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">21.21</font></td>
      <p ALIGN="CENTER">0.35</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">21.59</font></td>
      <p ALIGN="CENTER">0.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">21.96</font></td>
      <p ALIGN="CENTER">0.76</font></td>
      <p ALIGN="CENTER">26</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">22.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">22.7</font></td>
      <p ALIGN="CENTER">0.64</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">23.07</font></td>
      <p ALIGN="CENTER">16.47</font></td>
      <p ALIGN="CENTER">0.45</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">23.45</font></td>
      <p ALIGN="CENTER">16.86</font></td>
      <p ALIGN="CENTER">1875</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">23.83</font></td>
      <p ALIGN="CENTER">17.25</font></td>
      <p ALIGN="CENTER">138.56</font></td>
      <p ALIGN="CENTER">3.07</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">24.21</font></td>
      <p ALIGN="CENTER">144.85</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">24.6</font></td>
      <p ALIGN="CENTER">22.35</font></td>
      <p ALIGN="CENTER">176.35</font></td>
      <p ALIGN="CENTER">60</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">22.75</font></td>
      <p ALIGN="CENTER">207.84</font></td>
      <p ALIGN="CENTER">62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">25.38</font></td>
      <p ALIGN="CENTER">0.2</font></td>
      <p ALIGN="CENTER">100</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">25.73</font></td>
      <p ALIGN="CENTER">239.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">26.05</font></td>
      <p ALIGN="CENTER">245.62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">26.36</font></td>
      <p ALIGN="CENTER">23.53</font></td>
      <p ALIGN="CENTER">2375</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">26.68</font></td>
      <p ALIGN="CENTER">0.47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">0.23</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">27.33</font></td>
      <p ALIGN="CENTER">2687.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">27.65</font></td>
      <p ALIGN="CENTER">28.24</font></td>
      <p ALIGN="CENTER">365.29</font></td>
      <p ALIGN="CENTER">69</font></td>
      <p ALIGN="CENTER">5.89</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">27.98</font></td>
      <p ALIGN="CENTER">29.02</font></td>
      <p ALIGN="CENTER">2937.5</font></td>
      <p ALIGN="CENTER">403.07</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">28.31</font></td>
      <p ALIGN="CENTER">30.59</font></td>
      <p ALIGN="CENTER">3093.75</font></td>
      <p ALIGN="CENTER">453.46</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">28.65</font></td>
      <p ALIGN="CENTER">31.37</font></td>
      <p ALIGN="CENTER">484.95</font></td>
      <p ALIGN="CENTER">72</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">28.99</font></td>
      <p ALIGN="CENTER">31.76</font></td>
      <p ALIGN="CENTER">3343.75</font></td>
      <p ALIGN="CENTER">541.63</font></td>
      <p ALIGN="CENTER">6.66</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">29.34</font></td>
      <p ALIGN="CENTER">42.75</font></td>
      <p ALIGN="CENTER">3437.5</font></td>
      <p ALIGN="CENTER">566.82</font></td>
      <p ALIGN="CENTER">79</font></td>
      <p ALIGN="CENTER">8.96</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">29.69</font></td>
      <p ALIGN="CENTER">799.85</font></td>
      <p ALIGN="CENTER">83</font></td>
      <p ALIGN="CENTER">9.73</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">30.03</font></td>
      <p ALIGN="CENTER">14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">30.36</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">30.69</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">31.03</font></td>
      <p ALIGN="CENTER">18.04</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">31.38</font></td>
      <p ALIGN="CENTER">18.82</font></td>
      <p ALIGN="CENTER">2500</font></td>
      <p ALIGN="CENTER">56</font></td>
      <p ALIGN="CENTER">2.56</font></td>
  </tr>
  <tr>
  </tr>
  <tr>
      <p ALIGN="CENTER">32.14</font></td>
      <p ALIGN="CENTER">57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">32.53</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">32.93</font></td>
      <p ALIGN="CENTER">15.69</font></td>
      <p ALIGN="CENTER">53</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">33.33</font></td>
      <p ALIGN="CENTER">14.51</font></td>
      <p ALIGN="CENTER">47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">33.72</font></td>
      <p ALIGN="CENTER">11.76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">34.1</font></td>
      <p ALIGN="CENTER">11.37</font></td>
      <p ALIGN="CENTER">75.58</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">34.48</font></td>
      <p ALIGN="CENTER">69.28</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">34.87</font></td>
      <p ALIGN="CENTER">13.33</font></td>
      <p ALIGN="CENTER">2406.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">35.26</font></td>
      <p ALIGN="CENTER">88.17</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">35.66</font></td>
      <p ALIGN="CENTER">94.47</font></td>
      <p ALIGN="CENTER">43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">36.06</font></td>
      <p ALIGN="CENTER">15.29</font></td>
      <p ALIGN="CENTER">100.77</font></td>
      <p ALIGN="CENTER">189</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">36.44</font></td>
      <p ALIGN="CENTER">113.36</font></td>
      <p ALIGN="CENTER">48</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">36.81</font></td>
      <p ALIGN="CENTER">132.26</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">37.19</font></td>
      <p ALIGN="CENTER">157.45</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">37.58</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">37.95</font></td>
      <p ALIGN="CENTER">14.9</font></td>
      <p ALIGN="CENTER">50</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">38.34</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">38.73</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">39.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">39.53</font></td>
      <p ALIGN="CENTER">45</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">39.93</font></td>
      <p ALIGN="CENTER">119.66</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">40.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">40.72</font></td>
      <p ALIGN="CENTER">151.15</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">41.11</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">41.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">41.89</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">42.28</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">42.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">43.07</font></td>
      <p ALIGN="CENTER">0.31</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">43.47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">43.85</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">44.24</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">44.63</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">45.03</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">45.42</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">45.81</font></td>
      <p ALIGN="CENTER">16.08</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">46.2</font></td>
      <p ALIGN="CENTER">51</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">46.6</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">18.43</font></td>
      <p ALIGN="CENTER">0.55</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">47.39</font></td>
      <p ALIGN="CENTER">20.78</font></td>
      <p ALIGN="CENTER">3.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">47.78</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">48.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">48.45</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">48.77</font></td>
      <p ALIGN="CENTER">264.52</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">49.1</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">49.43</font></td>
      <p ALIGN="CENTER">340.09</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">49.75</font></td>
      <p ALIGN="CENTER">27.84</font></td>
      <p ALIGN="CENTER">352.69</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">50.07</font></td>
      <p ALIGN="CENTER">2656.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">50.4</font></td>
      <p ALIGN="CENTER">71</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">50.72</font></td>
      <p ALIGN="CENTER">32.16</font></td>
      <p ALIGN="CENTER">6.91</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">51.05</font></td>
      <p ALIGN="CENTER">478.65</font></td>
      <p ALIGN="CENTER">74</font></td>
      <p ALIGN="CENTER">7.68</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">51.38</font></td>
      <p ALIGN="CENTER">34.51</font></td>
      <p ALIGN="CENTER">522.74</font></td>
      <p ALIGN="CENTER">7.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">51.72</font></td>
      <p ALIGN="CENTER">36.47</font></td>
      <p ALIGN="CENTER">3062.5</font></td>
      <p ALIGN="CENTER">579.42</font></td>
      <p ALIGN="CENTER">78</font></td>
      <p ALIGN="CENTER">8.19</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">52.06</font></td>
      <p ALIGN="CENTER">3156.25</font></td>
      <p ALIGN="CENTER">7</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">52.39</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">52.71</font></td>
      <p ALIGN="CENTER">3406.25</font></td>
      <p ALIGN="CENTER">0.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">53.03</font></td>
      <p ALIGN="CENTER">44.09</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">53.38</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">53.76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">54.14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">54.53</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">54.9</font></td>
      <p ALIGN="CENTER">1718.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">55.28</font></td>
      <p ALIGN="CENTER">1593.75</font></td>
      <p ALIGN="CENTER">0.29</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">55.65</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">56.01</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">56.38</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">56.76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">57.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">57.49</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">57.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">58.22</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">58.59</font></td>
      <p ALIGN="CENTER">1312.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">58.96</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">59.33</font></td>
      <p ALIGN="CENTER">1343.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">59.7</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">60.06</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">60.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">60.8</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">61.16</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">61.53</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">61.9</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">62.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">62.64</font></td>
  </tr>
  <tr>
  </tr>
  <tr>
      <p ALIGN="CENTER">63.37</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">63.74</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">64.11</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">64.48</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">64.85</font></td>
      <p ALIGN="CENTER">14.12</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">65.22</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">65.59</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">65.96</font></td>
      <p ALIGN="CENTER">1562.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">66.35</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">66.74</font></td>
      <p ALIGN="CENTER">21.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">67.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">67.52</font></td>
      <p ALIGN="CENTER">214.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">67.87</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">68.18</font></td>
      <p ALIGN="CENTER">2562.5</font></td>
      <p ALIGN="CENTER">277.11</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">68.51</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">68.84</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">69.18</font></td>
      <p ALIGN="CENTER">3031.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">69.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">69.92</font></td>
      <p ALIGN="CENTER">1843.75</font></td>
      <p ALIGN="CENTER">220.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">70.31</font></td>
      <p ALIGN="CENTER">33.73</font></td>
      <p ALIGN="CENTER">0.02</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">70.69</font></td>
      <p ALIGN="CENTER">34.12</font></td>
      <p ALIGN="CENTER">2156.25</font></td>
      <p ALIGN="CENTER">101</font></td>
      <p ALIGN="CENTER">76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">71.03</font></td>
      <p ALIGN="CENTER">34.9</font></td>
      <p ALIGN="CENTER">77</font></td>
      <p ALIGN="CENTER">7.42</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">71.36</font></td>
      <p ALIGN="CENTER">36.08</font></td>
      <p ALIGN="CENTER">428.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">71.69</font></td>
      <p ALIGN="CENTER">37.25</font></td>
      <p ALIGN="CENTER">491.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">72.02</font></td>
      <p ALIGN="CENTER">37.65</font></td>
      <p ALIGN="CENTER">560.53</font></td>
      <p ALIGN="CENTER">10</font></td>
      <p ALIGN="CENTER">19</font></td>
      <p ALIGN="CENTER">102</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">72.36</font></td>
      <p ALIGN="CENTER">38.04</font></td>
      <p ALIGN="CENTER">648.7</font></td>
      <p ALIGN="CENTER">10.24</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">72.71</font></td>
      <p ALIGN="CENTER">38.43</font></td>
      <p ALIGN="CENTER">3562.5</font></td>
      <p ALIGN="CENTER">705.38</font></td>
      <p ALIGN="CENTER">11.78</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">73.07</font></td>
      <p ALIGN="CENTER">3500</font></td>
      <p ALIGN="CENTER">900.62</font></td>
      <p ALIGN="CENTER">103</font></td>
      <p ALIGN="CENTER">12.03</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">73.43</font></td>
      <p ALIGN="CENTER">3812.5</font></td>
      <p ALIGN="CENTER">831.34</font></td>
      <p ALIGN="CENTER">0.88</font></td>
      <p ALIGN="CENTER">104</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">73.77</font></td>
      <p ALIGN="CENTER">3687.5</font></td>
      <p ALIGN="CENTER">13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">74.1</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">74.43</font></td>
      <p ALIGN="CENTER">49.02</font></td>
      <p ALIGN="CENTER">409.37</font></td>
      <p ALIGN="CENTER">1.02</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">74.76</font></td>
      <p ALIGN="CENTER">49.8</font></td>
      <p ALIGN="CENTER">88</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">75.08</font></td>
      <p ALIGN="CENTER">547.93</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">75.42</font></td>
      <p ALIGN="CENTER">50.2</font></td>
      <p ALIGN="CENTER">2906.25</font></td>
      <p ALIGN="CENTER">617.21</font></td>
      <p ALIGN="CENTER">3</font></td>
      <p ALIGN="CENTER">16</font></td>
      <p ALIGN="CENTER">105</font></td>
      <p ALIGN="CENTER">10.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">75.76</font></td>
      <p ALIGN="CENTER">711.68</font></td>
      <p ALIGN="CENTER">12.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">76.1</font></td>
      <p ALIGN="CENTER">3281.25</font></td>
      <p ALIGN="CENTER">774.66</font></td>
      <p ALIGN="CENTER">9</font></td>
      <p ALIGN="CENTER">106</font></td>
      <p ALIGN="CENTER">13.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">76.45</font></td>
      <p ALIGN="CENTER">3250</font></td>
      <p ALIGN="CENTER">6</font></td>
      <p ALIGN="CENTER">192</font></td>
      <p ALIGN="CENTER">12.8</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">76.8</font></td>
      <p ALIGN="CENTER">3468.75</font></td>
      <p ALIGN="CENTER">812.45</font></td>
      <p ALIGN="CENTER">107</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">77.16</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">77.49</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">77.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">78.15</font></td>
      <p ALIGN="CENTER">47.84</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">78.47</font></td>
      <p ALIGN="CENTER">48.24</font></td>
      <p ALIGN="CENTER">466.05</font></td>
      <p ALIGN="CENTER">87</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">78.8</font></td>
      <p ALIGN="CENTER">503.84</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">79.12</font></td>
      <p ALIGN="CENTER">48.63</font></td>
      <p ALIGN="CENTER">554.23</font></td>
      <p ALIGN="CENTER">18</font></td>
      <p ALIGN="CENTER">9.22</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">79.46</font></td>
      <p ALIGN="CENTER">623.51</font></td>
      <p ALIGN="CENTER">11</font></td>
      <p ALIGN="CENTER">12</font></td>
      <p ALIGN="CENTER">11.01</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">79.79</font></td>
      <p ALIGN="CENTER">699.08</font></td>
      <p ALIGN="CENTER">13.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">80.13</font></td>
      <p ALIGN="CENTER">736.87</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">80.47</font></td>
      <p ALIGN="CENTER">762.06</font></td>
      <p ALIGN="CENTER">86</font></td>
      <p ALIGN="CENTER">12.29</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">80.8</font></td>
      <p ALIGN="CENTER">434.56</font></td>
      <p ALIGN="CENTER">0.9</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">81.12</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">81.43</font></td>
      <p ALIGN="CENTER">12.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">81.76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">82.09</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">82.42</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">82.79</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">83.18</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">83.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">83.97</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">84.37</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">84.77</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">85.17</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">85.56</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">85.96</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">86.36</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">86.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">87.15</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">87.55</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">87.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">88.34</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">88.73</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">89.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">89.52</font></td>
      <p ALIGN="CENTER">2218.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">89.92</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">90.32</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">90.71</font></td>
      <p ALIGN="CENTER">195.24</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">91.08</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">91.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">91.76</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">92.09</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">92.42</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">92.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">93.06</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">93.39</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">93.74</font></td>
      <p ALIGN="CENTER">27.06</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">94.07</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">94.4</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">94.72</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">95.04</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">95.36</font></td>
      <p ALIGN="CENTER">377.88</font></td>
      <p ALIGN="CENTER">6.4</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">95.69</font></td>
      <p ALIGN="CENTER">390.48</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">96.02</font></td>
      <p ALIGN="CENTER">29.8</font></td>
      <p ALIGN="CENTER">4</font></td>
      <p ALIGN="CENTER">7.17</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">96.33</font></td>
      <p ALIGN="CENTER">415.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">96.65</font></td>
      <p ALIGN="CENTER">30.2</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">96.97</font></td>
      <p ALIGN="CENTER">440.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">97.29</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">97.61</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">97.93</font></td>
      <p ALIGN="CENTER">2625</font></td>
      <p ALIGN="CENTER">472.35</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">98.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">98.62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">98.98</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">99.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">99.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">100.03</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">100.41</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">100.79</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">101.17</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">101.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">101.96</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">102.36</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">102.76</font></td>
      <p ALIGN="CENTER">2125</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">103.14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">103.52</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">103.9</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">104.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">104.65</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">105.03</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">105.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">105.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">106.22</font></td>
      <p ALIGN="CENTER">12.16</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">106.62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">107.02</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">107.41</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">107.8</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">108.19</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">108.57</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">108.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">109.32</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">109.69</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">110.06</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">110.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">110.79</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">111.17</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">111.55</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">111.93</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">112.31</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">112.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">112.99</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">113.31</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">113.64</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">113.97</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">114.3</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">114.62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">114.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">115.26</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">115.58</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">115.91</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">116.23</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">116.56</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">116.88</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">117.21</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">117.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">117.87</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">118.2</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">118.52</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">118.85</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">119.18</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">119.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">119.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">120.14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">120.48</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">120.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">121.16</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">121.5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">121.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">122.23</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">122.61</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">122.98</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">123.36</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">123.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">124.14</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">124.53</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">124.91</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">125.29</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">125.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">126.05</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">126.43</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">126.81</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">127.19</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">127.56</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">127.93</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">128.3</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">128.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">129.04</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">129.41</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">129.78</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">130.15</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">130.54</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">130.93</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">131.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">131.73</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">132.11</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">132.49</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">132.86</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">133.23</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">133.58</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">133.92</font></td>
      <p ALIGN="CENTER">32.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">134.24</font></td>
      <p ALIGN="CENTER">46.27</font></td>
      <p ALIGN="CENTER">81</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">134.58</font></td>
      <p ALIGN="CENTER">72.94</font></td>
      <p ALIGN="CENTER">92</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">134.92</font></td>
      <p ALIGN="CENTER">82.35</font></td>
      <p ALIGN="CENTER">604.61</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">135.27</font></td>
      <p ALIGN="CENTER">85.1</font></td>
      <p ALIGN="CENTER">3312.5</font></td>
      <p ALIGN="CENTER">749.47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">135.63</font></td>
      <p ALIGN="CENTER">86.67</font></td>
      <p ALIGN="CENTER">1001.39</font></td>
      <p ALIGN="CENTER">16.64</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">136</font></td>
      <p ALIGN="CENTER">86.27</font></td>
      <p ALIGN="CENTER">4250</font></td>
      <p ALIGN="CENTER">1020.28</font></td>
      <p ALIGN="CENTER">15.62</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">136.38</font></td>
      <p ALIGN="CENTER">4125</font></td>
      <p ALIGN="CENTER">1083.26</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">136.73</font></td>
      <p ALIGN="CENTER">3968.75</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">137.07</font></td>
      <p ALIGN="CENTER">51.37</font></td>
      <p ALIGN="CENTER">3625</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">137.42</font></td>
      <p ALIGN="CENTER">72.55</font></td>
      <p ALIGN="CENTER">91</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">137.75</font></td>
      <p ALIGN="CENTER">73.33</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">138.09</font></td>
      <p ALIGN="CENTER">77.25</font></td>
      <p ALIGN="CENTER">642.4</font></td>
      <p ALIGN="CENTER">5</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">138.43</font></td>
      <p ALIGN="CENTER">14.34</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">138.78</font></td>
      <p ALIGN="CENTER">84.71</font></td>
      <p ALIGN="CENTER">843.94</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">139.13</font></td>
      <p ALIGN="CENTER">869.13</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">139.49</font></td>
      <p ALIGN="CENTER">85.88</font></td>
      <p ALIGN="CENTER">881.73</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">139.84</font></td>
      <p ALIGN="CENTER">925.81</font></td>
      <p ALIGN="CENTER">96</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">140.17</font></td>
      <p ALIGN="CENTER">3843.75</font></td>
      <p ALIGN="CENTER">15</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">140.5</font></td>
      <p ALIGN="CENTER">3531.25</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">140.82</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">141.15</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">141.51</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">141.88</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">142.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">142.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">143.07</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">143.47</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">143.87</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">144.27</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">144.67</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">145.05</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">145.44</font></td>
  </tr>
  <tr>
      <p ALIGN="CENTER">145.82</font></td>
  </tr>
</table>
There is a little bit of cruising and a 2nd and 3rd gear weenie pull in there.
BTW...I screwed with the formatting of that table for like an hour and could not seem to get the height to decrease in size. Evidently html>me.
What kind of duty cycle are you seeing for the injectors and pulse width time?
See log above for pulse width. I didn't log the duty cycle...maybe I can get that on the next log.
Is the mod list in your profile up to date?
The only thing I noticed that I forgot was the prothane motor mounts. I added those to my profile once I realized I left them off. It is a pretty stock car that has been sitting for quite some time that I am trying to get back into decent shape before I start modifying it.
This is exactly what I was thinking. Everything I had read about phantom knock lead me to believe that i would see it during cruising and partial throttle with no boost. I am not really seeing any of that. It just seems to be knock when I am under load which makes me think it is real knock. That seems odd to me because everything is stock so I shouldn't be seeing real knock unless I have a major problem that I have overlooked.
I will read over that site about the plugs and get a new set of NGKs to give it a shot.
See log above. As you can see, hardly any (if any at all) knock while cruising. Also, you can see I got a little brave and pushed it to 85% throttle close to the end of the log. I am afraid to go to WOT with as much timing that is being pulled. If I really am experiencing true knock and the timing is being pulled that much, I don't want to risk damage to the engine or jumping time.
Seems to be no knock when free revving. Which to me was another indicator that this could possibly be real knock. :confused:
I fixed the code for the log as seen below:
Code:
<style>
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
@page
	{margin:1.0in .75in 1.0in .75in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;}
tr
	{mso-height-source:auto;}
col
	{mso-width-source:auto;}
br
	{mso-data-placement:same-cell;}
.style0
	{mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	white-space:nowrap;
	mso-rotate:0;
	mso-background-source:auto;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	border:none;
	mso-protection:locked visible;
	mso-style-name:Normal;
	mso-style-id:0;}
td
	{mso-style-parent:style0;
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
.xl24
	text-align:center;}
.xl25
	text-align:center;
	border:.5pt solid windowtext;}
.xl26
	text-align:left;}
</style>
<!--[if gte mso 9]><xml>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>1-18-09</x:Name>
    <x:WorksheetOptions>
     <x:DefaultRowHeight>264</x:DefaultRowHeight>
     <x:Selected/>
     <x:FreezePanes/>
     <x:FrozenNoSplit/>
     <x:SplitHorizontal>3</x:SplitHorizontal>
     <x:TopRowBottomPane>3</x:TopRowBottomPane>
     <x:SplitVertical>1</x:SplitVertical>
     <x:LeftColumnRightPane>1</x:LeftColumnRightPane>
     <x:ActivePane>0</x:ActivePane>
     <x:Panes>
      <x:Pane>
       <x:Number>3</x:Number>
      </x:Pane>
      <x:Pane>
       <x:Number>1</x:Number>
      </x:Pane>
      <x:Pane>
       <x:Number>2</x:Number>
      </x:Pane>
      <x:Pane>
       <x:Number>0</x:Number>
       <x:ActiveRow>408</x:ActiveRow>
       <x:ActiveCol>0</x:ActiveCol>
       <x:RangeSelection>$409:$503</x:RangeSelection>
      </x:Pane>
     </x:Panes>
     <x:ProtectContents>False</x:ProtectContents>
     <x:ProtectObjects>False</x:ProtectObjects>
     <x:ProtectScenarios>False</x:ProtectScenarios>
    </x:WorksheetOptions>
   </x:ExcelWorksheet>
  </x:ExcelWorksheets>
  <x:WindowHeight>11316</x:WindowHeight>
  <x:WindowWidth>22860</x:WindowWidth>
  <x:WindowTopX>96</x:WindowTopX>
  <x:WindowTopY>72</x:WindowTopY>
  <x:ProtectStructure>False</x:ProtectStructure>
  <x:ProtectWindows>False</x:ProtectWindows>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=1291 style='border-collapse:
 collapse;table-layout:fixed;width:970pt'>
 <col class=xl24 width=76 style='mso-width-source:userset;mso-width-alt:2702;
 width:57pt'>
 <col class=xl24 width=131 style='mso-width-source:userset;mso-width-alt:4664;
 width:98pt'>
 <col class=xl24 width=137 style='mso-width-source:userset;mso-width-alt:4864;
 width:103pt'>
 <col class=xl24 width=107 style='mso-width-source:userset;mso-width-alt:3811;
 width:80pt'>
 <col class=xl24 width=78 style='mso-width-source:userset;mso-width-alt:2787;
 width:59pt'>
 <col class=xl24 width=125 span=2 style='mso-width-source:userset;mso-width-alt:
 4437;width:94pt'>
 <col class=xl24 width=126 style='mso-width-source:userset;mso-width-alt:4494;
 width:95pt'>
 <col class=xl24 width=154 style='mso-width-source:userset;mso-width-alt:5489;
 width:116pt'>
 <col class=xl24 width=70 style='mso-width-source:userset;mso-width-alt:2503;
 width:53pt'>
 <col class=xl24 width=162 style='mso-width-source:userset;mso-width-alt:5745;
 width:121pt'>
  <td colspan=2 height=18 class=xl26 width=207 style='height:13.2pt;width:155pt'>TechnoMotive
  Datalogger</td>
  <td class=xl24 width=137 style='width:103pt'></td>
  <td class=xl24 width=107 style='width:80pt'></td>
  <td class=xl24 width=78 style='width:59pt'></td>
  <td class=xl24 width=125 style='width:94pt'></td>
  <td class=xl24 width=126 style='width:95pt'></td>
  <td class=xl24 width=154 style='width:116pt'></td>
  <td class=xl24 width=70 style='width:53pt'></td>
  <td class=xl24 width=162 style='width:121pt'></td>
 </tr>
  <td height=18 colspan=11 class=xl24 style='height:13.2pt;mso-ignore:colspan'></td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt'>Time (secs)</td>
  <td class=xl25 style='border-left:none'><span
  style='mso-spacerun:yes'> </span>Throttle Position (%)</td>
  style='mso-spacerun:yes'> </span>Engine Speed (RPM)</td>
  style='mso-spacerun:yes'> </span>Air Flow Hz (Hz)</td>
  style='mso-spacerun:yes'> </span>Knock Sum</td>
  style='mso-spacerun:yes'> </span>Oxygen Sensor (V)</td>
  style='mso-spacerun:yes'> </span>Timing Advance (°)</td>
  style='mso-spacerun:yes'> </span>Air Temperature (°)</td>
  style='mso-spacerun:yes'> </span>Coolant Temperature (°)</td>
  style='mso-spacerun:yes'> </span>ISC Steps</td>
  style='mso-spacerun:yes'> </span>Injector Pulse Width (ms)</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>0</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>19.22</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2250</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>107.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.51</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>97</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>184</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>54</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2.3</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>0.4</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>23.14</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2281.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>163.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.12</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>32</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>98</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>61</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3.84</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>0.77</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>23.92</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2343.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>233.03</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>31</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4.61</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>1.09</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2468.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>258.22</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>1.42</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>24.31</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2531.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>270.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.39</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>1.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2593.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>283.41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.66</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>64</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>2.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2781.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>289.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.7</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>2.39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2750</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>302.31</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4.1</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>2.72</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2968.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>308.6</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>34</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>3.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.55</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3000</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>314.9</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>38</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>3.41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>125.96</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.84</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>44</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1.28</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>3.79</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2843.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>56.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>4.18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2437.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.74</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>4.57</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>20</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2093.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>42</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>4.96</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>20.39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1937.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.08</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>58</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3.58</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>5.35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>19.61</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>188.94</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.04</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>5.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1968.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>182.64</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>49</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>6.12</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2000</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>81.87</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1.54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>6.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2031.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>62.98</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.78</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>6.88</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>7.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1781.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>29</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>7.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1625</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1.79</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1500</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.16</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>23</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>8.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1437.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>8.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>22</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2.05</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>9.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.14</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>24</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>9.46</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>187</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>9.83</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>13.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>21</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>10.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1406.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>10.57</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1375</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>10.94</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.8</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>11.31</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>11.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1531.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>12.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>17.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.72</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>12.42</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1468.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>28</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>12.81</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1687.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>170.05</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>13.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1656.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4.35</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>13.6</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>21.18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1750</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>59</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>13.99</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1906.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>201.54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>14.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2062.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>226.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>5.12</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>14.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>24.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2187.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>251.92</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>5.38</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>15.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>25.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2312.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.61</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>65</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>15.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>25.49</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>296.01</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>15.7</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>25.88</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>321.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>30</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>66</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>16.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>26.27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2718.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>333.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.49</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>99</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>16.35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2812.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>346.39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.21</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>16.67</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>26.67</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2875</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>371.58</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>67</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>5.63</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>17</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>27.45</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3187.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>384.18</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>17.34</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>28.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3218.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>396.78</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>68</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>17.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>29.41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3593.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>447.16</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>70</td>
 </tr>
 <tr height=18 style='height:13.2pt'>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>18.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>35.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3750</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>516.44</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>6.14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>18.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>38.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3781.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>667.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.53</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>80</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>9.47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>18.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>850.24</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>19.08</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3937.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>40</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>55</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>19.41</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3375</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>50.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>19.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3125</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>20.06</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>20.44</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>20.83</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>21.21</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.35</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>21.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>21.96</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.76</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>26</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>22.33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>22.7</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.64</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>23.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>16.47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.45</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>23.45</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>16.86</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1875</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>23.83</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>17.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>138.56</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3.07</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>24.21</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>144.85</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>24.6</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>22.35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>176.35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>60</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>22.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>207.84</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>25.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>100</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>25.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>239.33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>26.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>245.62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>26.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>23.53</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2375</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>26.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.23</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>27.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2687.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>27.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>28.24</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>365.29</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>5.89</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>27.98</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>29.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2937.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>403.07</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>28.31</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>30.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3093.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>453.46</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>28.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>31.37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>484.95</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>72</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>28.99</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>31.76</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3343.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>541.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>6.66</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>29.34</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>42.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3437.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>566.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>79</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>8.96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>29.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>799.85</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>83</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>9.73</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>30.03</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>30.36</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>30.69</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>31.03</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>18.04</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>31.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>18.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2500</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>56</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2.56</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>31.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>32.14</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>32.53</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>32.93</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>15.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>53</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>33.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>14.51</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>33.72</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>11.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>34.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>11.37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>75.58</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>34.48</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>69.28</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>34.87</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>13.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2406.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>35.26</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>88.17</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>35.66</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>94.47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>36.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>15.29</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>100.77</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>189</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>36.44</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>113.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>48</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>36.81</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>132.26</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>37.19</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>157.45</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>37.58</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>37.95</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>14.9</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>50</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>38.34</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>38.73</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>39.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>39.53</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>45</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>39.93</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>119.66</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>40.33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>40.72</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>151.15</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>41.11</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>41.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>41.89</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>42.28</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>42.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>43.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.31</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>43.47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>43.85</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>44.24</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>44.63</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>45.03</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>45.42</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>45.81</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>16.08</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>46.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>51</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>46.6</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>18.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.55</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>47.39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>20.78</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3.33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>47.78</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>48.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>48.45</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>48.77</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>264.52</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>49.1</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>49.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>340.09</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>49.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>27.84</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>352.69</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>50.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2656.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>50.4</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>71</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>50.72</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>32.16</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>6.91</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>51.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>33.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>478.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>7.68</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>51.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>34.51</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>522.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>7.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>51.72</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>36.47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3062.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>579.42</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>78</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>8.19</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>52.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3156.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>7</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>52.39</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>52.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3406.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>53.03</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>44.09</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>53.38</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>53.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>54.14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>54.53</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>54.9</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1718.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>55.28</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1593.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.29</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>55.65</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>56.01</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>56.38</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>56.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>57.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>57.49</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>57.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>58.22</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>58.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1312.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>58.96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>59.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1343.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>59.7</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>60.06</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>60.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>60.8</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>61.16</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>61.53</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>61.9</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>62.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>62.64</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>63</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>63.37</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>63.74</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>64.11</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>64.48</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>64.85</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>14.12</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>65.22</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>65.59</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>65.96</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1562.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>66.35</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>66.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>21.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>67.13</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>21.96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>67.52</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>214.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>67.87</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>68.18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2562.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>277.11</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>68.51</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>68.84</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>69.18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3031.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>69.54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>69.92</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1843.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>220.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>70.31</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>33.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.02</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>70.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>34.12</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2156.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>101</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>71.03</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>34.9</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>77</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>7.42</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>71.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>36.08</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>428.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>71.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>37.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>491.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>72.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>37.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>560.53</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>19</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>102</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>72.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>38.04</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>648.7</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>17</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10.24</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>72.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>38.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3562.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>705.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>11.78</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>73.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3500</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>900.62</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>103</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.03</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>73.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3812.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>831.34</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.88</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>104</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>73.77</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3687.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>74.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.77</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>74.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>49.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>409.37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1.02</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>74.76</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>49.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>88</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>75.08</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>547.93</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>75.42</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>50.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2906.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>617.21</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>16</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>105</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>75.76</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>711.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>76.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3281.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>774.66</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>9</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>106</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>13.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>76.45</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3250</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>6</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>192</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.8</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>76.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3468.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>812.45</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>107</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>77.16</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>77.49</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>77.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>78.15</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>47.84</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>78.47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>48.24</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>466.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>87</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>78.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>503.84</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>79.12</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>48.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>554.23</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>18</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>9.22</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>79.46</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>623.51</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>11</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>11.01</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>79.79</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>699.08</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>13.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>80.13</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>736.87</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>80.47</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>762.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>86</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.29</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>80.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>434.56</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.9</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>81.12</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>81.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>81.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>82.09</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>82.42</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>82.79</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>83.18</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>83.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>83.97</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>84.37</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>84.77</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>85.17</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>85.56</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>85.96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>86.36</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>86.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>87.15</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>87.55</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>87.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>88.34</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>88.73</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>89.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>89.52</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2218.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>89.92</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>90.32</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>90.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>195.24</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>91.08</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>91.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>91.76</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>92.09</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>92.42</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>92.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>93.06</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>93.39</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>93.74</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>27.06</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>94.07</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>94.4</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>94.72</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>95.04</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>95.36</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>377.88</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>6.4</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>95.69</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>390.48</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>96.02</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>29.8</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>7.17</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>96.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>415.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>96.65</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>30.2</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>96.97</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>440.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>97.29</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>97.61</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>97.93</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2625</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>472.35</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>98.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>98.62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>98.98</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>99.33</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>99.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>100.03</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>100.41</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>100.79</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>101.17</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>101.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>101.96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>102.36</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>102.76</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2125</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>103.14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>103.52</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>103.9</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>104.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>104.65</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>105.03</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>105.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>105.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>106.22</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>12.16</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>106.62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>107.02</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>107.41</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>107.8</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>108.19</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>108.57</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>108.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>109.32</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>109.69</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>110.06</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>110.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>110.79</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>111.17</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>111.55</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>111.93</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>112.31</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>112.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>112.99</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>113.31</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>113.64</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>113.97</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>114.3</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>114.62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>114.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>115.26</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>115.58</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>115.91</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>116.23</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>116.56</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>116.88</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>117.21</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>117.54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>117.87</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>118.2</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>118.52</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>118.85</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>119.18</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>119.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>119.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>120.14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>120.48</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>120.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>121.16</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>121.5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>121.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>122.23</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>122.61</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>122.98</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>123.36</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>123.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>124.14</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>124.53</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>124.91</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>125.29</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>125.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>126.05</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>126.43</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>126.81</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>127.19</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>127.56</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>127.93</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>128.3</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>128.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>129.04</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>129.41</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>129.78</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>130.15</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>130.54</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2343.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>130.93</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>131.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2468.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2.3</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>131.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.06</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>54</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>132.11</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.39</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>132.49</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2531.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>132.86</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>133.23</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>19.22</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2593.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>133.58</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>32</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>61</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>133.92</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>32.94</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>270.82</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>134.24</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>46.27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>81</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>134.58</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>72.94</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>92</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>134.92</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>82.35</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3000</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>604.61</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>135.27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>85.1</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3312.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>749.47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>135.63</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>86.67</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1001.39</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>16.64</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>136</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>86.27</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4250</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1020.28</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>15.62</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>136.38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>10.2</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>4125</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1083.26</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>136.73</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3968.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>137.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>51.37</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3625</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.84</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>137.42</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>72.55</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>91</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>137.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>73.33</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2843.75</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>138.09</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>77.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>642.4</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>5</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>138.43</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>14.34</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>138.78</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>84.71</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>843.94</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>139.13</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>869.13</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>139.49</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>85.88</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>881.73</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>139.84</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>925.81</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>96</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>140.17</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3843.75</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>15</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>38</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>1.28</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>140.5</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>3531.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>62.98</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>140.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>56.68</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>39</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>141.15</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2781.25</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.78</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>141.51</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.7</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>187</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>141.88</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.68</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>142.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>142.67</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.74</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>143.07</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2281.25</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>143.47</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>143.87</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2250</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>37</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>144.27</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>144.67</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>145.05</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.59</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>24</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>145.44</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>0.08</td>
 </tr>
  <td height=18 class=xl25 style='height:13.2pt;border-top:none' x:num>145.82</td>
  <td class=xl25 style='border-top:none;border-left:none' x:num>2093.75</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=76 style='width:57pt'></td>
  <td width=131 style='width:98pt'></td>
  <td width=137 style='width:103pt'></td>
  <td width=107 style='width:80pt'></td>
  <td width=78 style='width:59pt'></td>
  <td width=125 style='width:94pt'></td>
  <td width=126 style='width:95pt'></td>
  <td width=154 style='width:116pt'></td>
  <td width=70 style='width:53pt'></td>
  <td width=162 style='width:121pt'></td>
 </tr>
 <![endif]>
</table>
I will see if I can check the fpr to see if it is functioning properly.
I have set the base timing and re-checked it and it is right at 5 deg. BTDC.
When you are at 10.2% Throttle is your foot off the pedal? If so then you need to adjust your TPS to zero or near zero percent.
If the ecu thinks your at WOT and the butterfly valve is not fully open that might create problems.
Also, get some new fuel just to make sure it's not a fuel issue!
**UPDATE**
I know it has been a while but i finally got around to working on the car again. I decided that I would check my fuel pressure to see if there was an issue with my stock fpr. I found that the static pressure was around 47ish psi and with the car running and the vacuum line on, the pressure was around 38ish.
From the research I have done, the static pressure for a 1g should be 38 and the pressure should drop from there with the vacuum line on. I ordered another fpr and should have it in sometime next week. We will see if that fixes the issue.
