steve
DSM Wiseman
- 17,382
- 4,045
- Feb 3, 2002
St. Charles,
Illinois
I think so.spyderturbo007 said:Steve, are you the person that everyone sends their ECU to for repair, inspection and cap replacement?
The conformal coating on the ECU board tends to hold the capacitor leakage under the caps initially. It's not unusual for there to be no signs of leakage other than operational and once the caps are pulled find a hole in the main power traces under C108. At least find someone who can loan you their ECU for a test to see what happens. I've seen plenty of pristine looking ECUs that didn't work right because the caps leaked.Gromit said:Nathan & Steve - as far as the ECU goes, I can't rule out a problem that wasn't visible & no, I'm not an electronics expert. But I do have experience with computer boards & upgrades & have seen overheated or burned out chips. I can tell you that this board looked pristine - like it had just come from the factory. There was no oozing green gunk, no nasty dead fish smell, no burn marks, no dust, no nuthin'. So at this point I'm not inclined to think that's the problem. Instead, since we might go with the upgraded ECU down the line, I'm going to leave it for now.
Steve
I think this was more than I needed to know...
We actually work on the car together & she's fully apprised of the whole situation. She's also got a degree in engineering so you'd better be prepared to blow differential equations in her ear.
I've read stuff alluding to the need for a daughterboard to override the existing micro-chip controller & allow for the socket. Is that the ticket, or would I have to somehow procure an EPROM ECU to use the custom chip?
Well, that makes things a little more problematical. Let's say that ultimately I plan to get an EPROM ECU, have it socketed & custom chipped, upgrade the MAS to a 3G, & get bigger injectors. I'm wondering about these 2 routes:
FTRM & FTRH are both good, although not fully settled yet as I haven't done a lot of higher throttle cruising since installing the chip. And I cannot correct the FTRL with the SAFC - adjusting to the full -50% does not change it at idle. The chip guy suggested just lowering the base fuel pressure as the injectors were likely flowing more than they were rated for. Any thoughts on this?
