ECMlink LinkTools 5.4 questions
Yamahaulin
695
12
Jan 30, 2010
Bowling Green, Kentucky
I have had linktools 5.4 since he put it out but have just now switched my car to SD, so i have never opened it up till today. I know you can no longer get this unless you know him, and i'd like to add this is for my use only would never make money with it. I use office 2003 with this, when i import a log file when i want to move where the cursor is in the log it doesn't move to where i click it's skewed to the left some. Does anyone know how to fix this or have incountered this problem before. Also when setting start stop markers it doesn't work correctly either but luckily you can type in the spot you want them and i do it that way. This program seems completely awesome if i could just get it to work a bit better.
Why not message @Calan and ask him directly!
I had planned on it but thought maybe some else has had this problem too.
The problems you speak of exist in the earlier versions. Like stated above, you should contact Calan about utilizing his program.
I have pm'd him to see if there is something that can be done. Thanks for the help.
