2G Leaking oil in spark plug valley
OwenRonn
10
Mar 25, 2026
gulf shores, Alabama
I am leaking oil from somewhere in the spark plug valley it started shortly before I did an engine pull so I replaced valve cover gaskets and the spark plug gaskets. Back to driving the car after the engine was back in and it was still leaking in the same spot I just replaced the gaskets again and it is still leaking from there. Even though I replaced the spark plugs while I had the engine out I havent noticed any kind of misfire or fouled plugs before or after the engine pull dispite the oil presumably coming from there which is starting to make me think its coming from somewhere else in the valley.
Check around the bolts for small cracks especially the one in the corner on the timing belt side/IM side. Unfortunately, the valve covers on these cars are not the best material. Sometimes if a bolt is overtightened or not the correct length it can cause cracks. It happened to mine.
Also remember that these are not your average aluminum. So if you go to weld it, it will be more challenging then just welding aluminum.
I will check them, what do you mean by not your average aluminum, just really thin and crappy? would I be better off trying to find a business that might do it or should I just replace it entirely with one made of a stronger material, if those exist.
I was told by someone that they are a mix of aluminum and magnesium or something. Basically, it is dirty aluminum, and it makes for a very sloppy, dirty weld. Not that I have personally experienced it but only what I have heard.
The oil cap seal could be another source.
That's where mine used to leak. Changed the gasket to a new soft one and still did but not as much. Retensioned the spring clip on the bottom of the cap and the combination fixed it.
I am going to order a new evo 8 oil cap and seal and see if it makes a difference I read that the oil can be a common problem but the only thing that makes me doubt it is that I havent seen oil residue around the oil cap. I know the pic I took wasn't great but you can see that there isn't residue around the cap.
This may be a bad idea but If it were me, I'd just clean everything really good, put some paper towel around the oil cap, and then let it run for a little to see if the paper towel seems to be picking up any oil from the cap. It may also show the general area that it's leaking from if not the cap.
Obviously the biggest thing to be careful of here is fire...paper, oil, heat, not the best combo
I had this oil in the valley problem for years and never could find out exactly where it was coming from.
It turned out to be a small crack somewhere in the valve cover. I never saw it.
Even English Racing didn't see it until they put the car on the dyno to start tuning it, and then they discovered the oil coming out.
They didn't try to repair the valve cover. I don't know why. Maybe it's like tschuhly is saying about the difficulty of welding it. Anyway they just emailed me and said the valve cover is cracked, we'll have to find a good used one somewhere. Which they did.
A few people in here have bought fancy expensive new ones from, forget now who, I'd have to look it up.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
