Leaking coolant
ikeshaun
May 10, 2011
California, California
Hey guys.Well..my cars leaking coolant right below the timing/alternator belt area.Its not a constant leak when the cars off,but only after the cars been on for a minute or two.Would that be a leaking water pump,or is there a hose or something that could be the cause of it?My cars lowered a bit...and I dont really wanna put it on jack and climb underneath it=[
P.S.-I checked the other coolant leaking threads and they dont
All input is greatly appreciated.Thanks in advance!=D
You don't want to put a jack under it? Why lower it? No matter what, you will have to lift it or pay someone else to do it to really see where the leak is coming from.
I bought it lowered.I only have 1 jack which wouldnt get it very high=[
Thanks though,Ill try to see if any of my friends have ramps or somethin so I can get underneath
Check your hoses and clamps, maybe your thermostat housing. Also check the weep hole on the water pump if it has coolant tracking then the pump will need replaced.
