leak? Intercooler piping/couplers?
BoostinGSX17
50
Mar 22, 2007
Sicklerville, New Jersey
I have a FMIC and today i was driving around and i heard a big pop. I figured it was my coupler blewing off. So i looked and it was so after fixing it I cant get any boost. Instead of hearing my turbo spool and build up boost all I hear is like a sucking of air sound of something along those lines i checked all my couplers they seem fine and its a brandnew one on the one that blew off.
ok i tried to figure it out becasue i dont ahve a boost leak tester and liek it doesnt seem to like sucking in but yet pushing out on the passenger side like once boost starts to build you jsut heard pshhhhhhhhtttttttttt then my BOV might sound off i have a type s do you think the BOV could be stuck?
You have a HUGE boost leak some where. It doesnt sound like its the bov. Best thing to do is take out the piping, couplers, and inspect them 1 by 1, since you dont have a boost leak tester.
Don't forget a bottle of soapy water to spray on the possibly areas to isolate the hissing sound. The soap will bubble giving you a "There's Your Sign."
Boost leaks and popping off IC piping has always been a huge problem. I have been looking around for ever for a fix and I have finally found it. Linder Power Systems have come out with a Intercooler Coupler that is pressure tested to 150 psi without failure and they look trick as hell. They have them in 2.5", 3", and 4". They are trick little thread together couplers and work like none other. Check them out @ Linder Power Systems, Formerly Alien Auto :: POWER is our MIDDLE Name!. The best part about the product is there half the price of wiggans and the don'e seperate at 50psi.
