Intercooler piping boost leak help
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
so this problem happened before and i fixed it but now its pissing me off
the hose is cut in the middle for a piece of metal with a welded on turboxs blow off valve to go on.. then the rest of hose it curved
well i put the hose back on and tightened it so it wont move.. i can rev as much as a want and no sign of the hose falling off
but once i build boost driving on it the hose shoots right off..
im only running 11 pounds..
i bought 4 new clamps too ..
wtf is going on
Is your IC piping aluminum or steel? Does the coupler have any physical damage?
I also second the recommendation for t-bolt clamps. They're the only way to go.
And as for the hairspray trick - copper spray also works well for those of you lucky guys that don't live with a woman and her bathroom full of care products. ;)
clean it up real good and do the hairspray trick, and get some good t-bolt clamps and see if that helps,
P.S. if you can do what the_mork told you do that too
