KYB AGX adjustable question?
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
Hey i heard u need to use AWD rear struts when lowering my car it is a FWD but thet FWD rear struts will bottom out they said? im using eibach sportlines will this effect anything? also will the sportlines make the car to low for 18" rims? and i also heard i do not need a front camber kit only rear? and does anyone hav any opinions on the KYB AGX's with the sportlines a good setup?
Thnx
Terry
i personally think the sportlines drop the car too much for comfort, specially the FWD. I would stick to the FWD struts but go for a spring that will lower the car less like the Tanabe GF210 or the Tein S-Techs. If you are set on Eibach, the pro kit is pretty nice too.
So if i use the pro-kit i will be ok with using FWD struts and just a camber kit?
Terry
