Ksport kontrol 1g questions
DROPthatCLUTCH
483
4
Feb 21, 2011
Calgary, AB, Canada
Do I need the front camber kit, since the fronts have camber adjustable top mounts.
What will I need for a rear camber correction kit? Adjustable control arms?
I'm about to spend about a grand on the kontrols, not including whatever else I'm going to need to run them properly.
I'm pretty set on these coilovers, but if you have had a good experience with a different strut/spring setup for a DD for cheaper, I'm all ears.
Nothing else needed for the front, the top mount gives more camber adjustment than the normal eccentric bolts anyways. For the rear, I would do lower adjustables, give you a little more room for a wide wheel/tire combo over pushing out the upper control arm.
Yeah, don't get them and save your cash for something better. Seriously.
