DROPthatCLUTCH's Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
GT35 Variant
Drivetrain
AWD
Build Type
  1. Street
FP alluminum intake pipe, Alluminum sheet metal intake manifold, PW GT3582r Turbo w/ 0.63 A/R turbine housing, FLspeedfab top mount turbo manifold w/ bumper/hood exit exhaust/wastegate dump, RTM aluminum duel in-tank fuel pump hanger/sending unit w/dual Walbro 255LPH pumps rewired, -8AN SS braided fuel feed, -6AN return line, FuelLab in-line filter, FuelLab AFPR, FIC 1150cc injectors, Full emissions delete, Godspeed FMIC w/ 2.5" piping, Knock off greddy BOV custom diaphragm, A/C delete, JayRacing saturn alternator relocation, Custom 3" v-band bumper dump exhaust pipe, Modified Knock off greddy catch can from 2 -10AN fittings welded in valve cover, Prothane motor mount inserts, Devils-own methanol injection 10 GPH nozzle, Greddy magnetic oil drain plug, Hallman pro MBC
Mods-Engine
Eagle forged 100mm Crankshaft polished, ARP main studs, Eagle H-beam Connecting rods, ARP rod bolts, Wiseco 9:1 forged pistons, ACL Race main and rod bearings--standard size, Kiggley girdle, Balance shaft delete, OEM Straight cut oil pump gears in OEM front case, Felpro permatorque MLS head gasket, Cometic gaskets all around, 1g Cylinder head ported/polished, SBI 1mm oversized SS valves, Bronze valve guides, Manley valve springs, Titanium retainers, DKS 272/272 camshafts, fidanza adjustable cam gears, ARP head studs, Kiggley HLA oil pressure regulator
Mods-EMS & Logging
ECMlink v3 speed density w/ GM IAT sensor, Omnipower 4 bar MAP sensor, Autometer boost/vacuum gauge, Apexi turbo timer, Innovate MTX-L wideband, Glowshift oil pressure gauge - sending unit relocated with -4an braided SS lines
Mods-Drivetrain
2g shift knob, Stock 1g 23 spline trans., Welded center diff, Fidanza lightweight flywheel, Southbend SS-X-Series Pressure Plate, ACT 6-puck sprung clutch disc, SBC Throwout Bearing, Brass cable bushings, Alluminum shifter plate bushings, SS braided clutch line master to slave, OEM slave cylinder w/ restrictor removed, Forged steel competition clutch fork and pivot ball
Ksport kontrol coilovers, Wedsport SA70 wheels
DROPthatCLUTCH
More in 1G DSM
Share this Vehicle
