ThetanuRucka
- 49
- 0
- Dec 15, 2011
Fayetteville,
Arkansas
i just picked up this 2nd gen from a friend. its got v3 in it. rebuilt 4g63 1g head 2g ported manifold and 20g turbo. FMIC blah blah. 880cc injectors.200whp
i took it out last night and thought i had it tuned pretty well. 11.3 afrs at like 16-17psi. i was happy with that for day one of owning the car.
well weird stuff started to happen. drove it to a friend house. 360whp GTO owner and and 300whp Mustang owner. they wanted to see it run so whatver, i turned it up a half turn. got on it, 2nd gear the car felt good but was slightly lean for me 12.0-12.2. so i got out of it. and did a third gear pull. afrs went to 13 and i got some knock. backed out. turned the boost back down. and went for a ride. 9.0s in boost.... and the occasional knock on the long third pull. and the car felt like it was just loading up on fuel, just that dead feeling on accelleration?... well we were leaving so i said **** it and just left. got on the high way and made a pull on the on ramp. 10.0 afr now.... betterr but...
drove about 20 miles and made another pull. 13.5 afrs no knock.
20 miles later 10.0 afrs slight knock. (didnt have my comp with me this whole time).
2nd gear on 16-17 psi with a 12g on street tires should light up or at least bark.
. nothing. just that ****ty dead feeling. car just didnt feel right. so today i got my comp, did some logging at the end i ended up pulling 8 degrees of timing and the knockret stayed the same.also one of them shows me spiking to 19. and holding 14ish. (est. boost).
all afrs on this were more like high 10s. 2nd gear was lower 10s.
any help much appreciated. i just made the switch from hondas and hondata/neptune MAP tuning and will be switch to SD shortly but for now. MAF tuning will be okay.
all this done on shell 93.
2000 mile motor.
. nothing. just that ****ty dead feeling. car just didnt feel right. so today i got my comp, did some logging at the end i ended up pulling 8 degrees of timing and the knockret stayed the same.also one of them shows me spiking to 19. and holding 14ish. (est. boost).all afrs on this were more like high 10s. 2nd gear was lower 10s.
2000 mile motor.
