keydiver chip
bmac92185
Jan 4, 2009
schofield, Hawaii
ive searched but havnt come up with much and nead to find out if i can use this or if i have to buy a new one. i have a 93 tsi, 16g and-recently ordered and on thee way- 550cc inj, 2g maf and a walbro 190. my eprom is being fixed and socketed as i write this also. my brother was building a car for his wifes nephew and the kid blew it up allready. anyway he has a new keydivers chip for the nephews car who had the same set up as me. except his was 5 speed and mine is auto. will i be okay using this. i asked jeff at keydrivers and here was my reply. can anyone help me out please?
i asked:
hi. my
> brother has chip that was made for another car. the only
> difference is mine is an automatic and his was manual. i
> think they are the same year also. they were both 1 gs for
> sure anyway. will this work in my car??
Bob,
The maps are slightly different for a 5-speed, a little more aggressive, but nothing to worry about. But the A/T base fuel pressure is 43psi, while the 5-speed 1G base fuel pressure is only 36.3psi. You will have to find some way to correct for that.
Jeff O.
Pick up an afpr (adjustable fuel pressure regulator). It will let you adjust your fuel pressure. Do a quick search, you'll find Aeromotive is the most common. I bought my Fuel Lab AFPR kit from ModernPerformance. It comes with everything you need to bolt it up. I'm going to run this same setup only with 560cc injectors. ECU is getting socketed as we speak.
Good luck!
Yep you can use that chip, like the guy before me said just pick up an AFPR and set the pressur where you want it.
