Keydiver stage3 chip NOT WORKING PROPERLY!
kwaliph
80
Sep 7, 2005
Yuba City, California
First of all,
I am not even close to ruling out the possibility of it being me not installing the new clutch wire successfully but I followed the install instructions from TMO quite closely.
Here is the problem,
After finishing the ~30 min. install of the clutch wire kit, I go to test:D. I activate the launch stutter box flawlessly:rocks: :rocks: :rocks:. Now I am gonna test the NLTS stutter box, here is where something is not right. I floor it in 2nd and it stutters at 5500 with the clutch not being touched :notgood:. Just last night I wass hitting 7k and loving it but now it won't go past 5500 wether the clutch is in or not :mad:.
What would cause this? Is my install job screwed up somewhere?
Please, any help would be greatly appreciated.:dsm:
I have everything set up to read the voltage at the connector to ECU while pushing the clutch in and out. I check continuity since I was there, none :|.
Well it turns out that was the culprit all along. I could have sworn I checked for continuity after I put that thing on :toobad:. I just want to apolagize for this crap all because I probably forgot to check my work :(.
I am so thankful for the knowledge you guys shared with me. I would still be at it if I hadn't posted at all :notgood:.
As far as the stutter box,
It works flawlessly now. HOLYCRAP I love this feature. :thumb:
Thanks again guys.:dsm: :dsm: :dsm:
jessesgsx said:
i bought a 95 gsx and had the same chip in it, it did the same stuff i got so frustraded i just took it out and got safc man you will love it and its easy to install..
1. What are you talking about? This thread was for the purpose of installing the stutter dox on the KD chip.
2. I already have a SAFC. A programmed chip is better than SAFC anyday of the week.
SAFC will throw off your fuel maps where as the chip will be preprogrammed to run your setup with no side effects :thumb:.:dsm: :dsm:
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
