Wastegate not working properly?
lars y
141
Oct 11, 2007
Halden, Europe
Hi,
I think i am having trouble with either the wastegate or the boost controller.
Even though i have the boost controller set to the minimum setting i`m still getting over 30 psi of boost.
At 6000 rpm i read in Ecm-Link that i had 37 psi.
I have a GT3076r, is this boost level damaging for the turbo?
The wastegate is a Tial F41 with a 0.9 Bar spring.
I am pretty sure i have it all hooked up properly, on the pipe right after the turbo i have a nipple with a hose to the boost controller and a hose from the boost controller to the lower nipple on the wastegate.
Thanks
Manual, one i bought from Slowboyracing.
EDIT: here`s a picture Btw.
Have you tried another one to see if the same problem persists? or tried swapping the lines as it could hooked up wrong?
I just had a faulty controller had to send it back for a new one. Manufacturer defect spring was no good.
Have you tried hooking a line straight to the wastegate (no boost controller)?
I haven`t tried much yet, just bought a new softer spring and going to swap it out.
I will try out a handpump and also try bypassing the boost-controller.
Thanks for the tips.
Alright, found out that the spring and ball inside the boost-controller had gotten stuck, took it apart and assembled again, i have no idea how it happened as i tried it before i put it on the first time, hope it doesn`t get stuck again.
Now, what pressure should i aim to set it to?
Thanks
