just how fast......
Status
Not open for further replies.
gstfairy
Nov 18, 2004
marietta, Georgia
this is my first time posting a thread so i will start it off with a really stupid question. at top speed just how fast will my gst spyder go? it is really important that i know. if you know... tell me.
i dont know man, i dont think i have big enough balls to push it on the verge of blowing my engine.
Use the tach
Your car has a speed limiter that cuts you off at 130mph
This is because the stock H-rated tires are only rated up to 130 MPH
my speed limiter stops me from going any faster than 125mph.
I rode on it for a few minutes and was scared out of my ballz of . .
a) dying
b) going to jail
but i did it just so i can say to myself i've been there.
the car hit 125mph and didnt even think twice about it. If the limiter wasn't there, i'm thinkin ~135mph would be top speed
my speedo is calibrated up to 80 for sure, i had it pegged at 80 w/ cruise when i went by one of those white cop boxes that tell you your speed and it was right on. I've had the needle buried right after 145 on mine once, and im not going to do it again for a long long time. everything w/ tires and rims are stock so thats not going to mess w/ it. bigger rims would be faster than speedo anyways. Is the speed cut maybe removed or is my speedo off by that much at higher speeds?
Mine was 140 and still creeping up, but I got scared and my lapse of insanity ended, so I let off the gas. That's what the speedo said anyways... sure felt like 140
http://members.shaw.ca/costall/1000Q/answers-makeandmodel.htm
"What is the top speed of my car?
Top speeds will obviously vary with the modifications to the vehicle. However, the top speeds for stock vehicles are in the following neighborhood:
- 1G AWD: around 140 MPH / 225 km/h
- 1G FWD: 140 MPH / 225 km/h
- 2G AWD: somewhere around 130-140 MPH.
- 2G FWD: some cars are speed limited to 130 MPH
Is there a rev limiter on my car?
As far as is known, the ECU will stop fuel delivery on all the DSM cars at 7500 RPM.
Some 2G FWD cars have a speed limiter which cuts off fuel at 130 MPH. This is because the stock H-rated tires are only rated up to 130 MPH."
alright thanks guys. this is only the beginning with me and my car so i really wanted to see what kind of speed it has.
Your speedo is going to be further off the faster you go because the centrifugal force of the tires spinning espands the tire itself, increasing it's outside diameter.
the top speed of a car is by no means any way to gauge how "fast" a car is. Thats what i think he is doing. I think this is a hhow fast can your car go? oh well mine can go faster. Maybe.. but if it takes you twice as long to get there.. are you really faster? Top speed means nothing.
mine is speed limited at 137mph. 135 all day long, no problem...stock drivetrain...225/40/18...like above said: h rated tires on the fwd turbo, the limiter is set around 130ish. supposidly(sp?) awd is not speed limited, came w/z rated tires.
jim :dsm:
Top out my 2G GST @132MPH and after that the fuel cuts off.
Top out my frends @G GSX @139MPH and after that the fuel cuts off.
the speedometer is preatty accurate i gotten a ticket before going 95mph and i was on a curise control when i got pooled over :thumbdown (luckyly it was in IN so he let me go w/worning)
no im not just asking because my speedometer reads that high i was just curious.n one more thing, if i get performance rated tires can i do something with that speed limiter on my car?
i dont really have an hour to spare trying to get to 160, me and my friend were arguing over its absolute top speed.....no limiters.
my fuel didn't cut off when i hit the speed limiter.
What happened was thee was a smooth acceleration all the way up to 125mph, and as soon as 125mph hit, the acceleration just stopped and the car cruised there unless i let off the gas.
Status
