Just got Tial 38mm Wastegate
Itlooksfast
128
Jun 25, 2005
Alexandria, Virginia
This is brand new and i havent install it in yet but i got a question. Do i need an adapter to install in onto the manifold? do i need anything else to do the installation? i wanna buy all the parts first before i put it on.
Which manifold are you running? Also, which turbo are you running?
stock ported 2g manifold....and a PTE SCM3427 turbo.
brute: are you talking about the flange for the wastegate or the dumptube or both?
I was looking at the parts catalogue and some pix....it seem the o2 housing and dumptube look at same. Are they same or do i actually have to get them both?
i want it on the 02 housing and if somehow i cant do that i wanna flanged my 2g manifold for the wastegate.
how would i put it on my o2 housing? ### i was looking at it and it seems like the flange on the Tial cant fit in any of flange on the o2 housing. Do i need to do any welding of the Tial flange to the o2 housing?
Either way if i weld the flange to the O2 housing or the manifold, i dont need a dump tube right? ### i thought the o2 housing and dumptube are similar.
Here's a pic of the O2 housing you would need:
And this is what it would look like when the wastegate and dump tube are bolted to it.
No matter how you do it, you will need a dumptube to route the exhaust gas down and out of the engine bay.
so is there anything i can with the EVO3 o2 housing that i got to make it work with the Tial?
Thanks you for the pics...very helpful. Alrite so the dumptube is the pipe that connect to the o2 housing and the wastegate right?
No. If you choose to use your current O2 housing, then you will need to install the wastegate on the manifold.
No. The dumptube is that long tube in the second picture. It connects to the exit of the wastegate and it's purpose is to route the exhaust gas away from the wastegate and out from underneath the engine bay.
Do you understand how a wastegate works?
yea...it vents the access boost pressure out to the atmosphere...and yes i was talking about the same tube, just i described it wrong i guess but its the long tube that i was talking about.
If i decided to install it to my 2g ported manifold....what do i need to do? weld the 38mm wg flange to it and install the Tial wg?
i rather work with what i got then spend 300 or more on something that i already have.
No, actually, that is what a bypass/blowoff valve does...
You'd have to do what I did last year. click here
hey thanks for answering my question...really appreciated.
so what i cant install the Tial into my evo3 o2 housing? is there anyway i can make that work? Dont really want to buy a new o2 housing.
alrite my friend can weld the flange to the manifold and attach my Tial wg that way...
But where can i get the dumptube by itself?
Itlooksfast said:
cool thanks....i would give a reputation point but i dont know how.
You give another member reputation points, just click
on the helpful post. :thumb:
