just got a new eagle talon
Sick_Boy
Feb 1, 2008
Freeland, Washington
I just baught a 90' eagle talon all-wheel drive with a first gen GSX motor. What kind of performance upgrades would anyone recommend that I use. Also good places to go to buy anything that I might want.
I would first go through all of the maintenance. Then make some goals as to how much power you want, then ask this question again.
Go and do all your maintenance and make sure you change that T belt and balance shaft belt, if they havent been changed or you dont know when... then follow the upgrade path..
First do ALL the maintence to the car, you don't want to be driving an oil leak. its not safe:nono:
Then once you assure yourself that all the bugs are out, you should look into getting the most common things such as intake and exhaust.
Go buy a Chilton book from an auto store on the 1G cars and follow all the maintenance as said before and then you should also look into a compression check to see how well your engine compression is. Replace all things that look worn out or are leaking. Then you can look into following the upgrade path on the site as mentioned before Tech Guide: 1G 4G63t Upgrades - DSMtuners .
Sweet bleeding jesus christ on a pogo stick. Not another one.
