jack slipped with motor mounts gone
Ahh.... Crushed oil pan??? Were not there to visibaly inspect what could be broken. You will have to get a hoist to lift the engine up and inspect the damage. How did you have the jack holding your motor up with out motor mounts. Please dont tell me it was under the oil pan!!
no oil pan is ok we had. two jacks for it holding it up will putting the tire back on.had to return the tools so when were taking the jack form the oil pan off. got it off and the other jack slip all tires were on. my ? will it casue any damage to the engine with out the motor mounts yes i am a noob. first timing belt job not enough cash for a shop so yea work with here.
You just need to inspect for any damage. We really couldnt tell you what could be broken not being there to see. Just look for and wires pulled out or connectors, axles for and damage to the cv boots, intake boot pulled off and any other things that could have been crushed by the weight of the motor. If you are wondering if you damaged the motor, my answer would be very doubtful.
